SocialTwist Tell-a-Friend
Design of Two way slab with wall load
G.Manjunath
PostPosted: Fri Sep 23, 2011 10:03 am    Post subject: Design of Two way slab with wall load Reply with quote
Respected sefiens,
Can any one guide me how can i design the two way continuous/discontinuous slab with  200/230 mm thick  wall on it.
Manju
mofizahmed
PostPosted: Fri Sep 23, 2011 12:06 pm    Post subject: Reply with quote
General procedure:Calculate the total wall load(volume x unit weight ) divide it by total area of slab.You will get load in terms of unit/area (e.g. Kn/m2),add this load to other loads like live,dead,sdl,etc. to get design load.Now design as per is 456,you can refer to any standard book of RCC.For rigorous analysis you can use Yield line method,plate theory or even FEM.Lots of related topic is available in this forum,do a search.
rajancivildesign@gmail.co
PostPosted: Fri Sep 23, 2011 1:59 pm    Post subject: Bending moment for wall supporting two way slab Reply with quote
Dear SAFIAN,
The bending moment due partition wall (along short and long wall or both directions) can be calculated using the formula based on Pigeaud's theory as given in Reynold's hand book or
hand book published by
PWD/Tamil nadu with worked out example.
V.M.RAJAN.
aditya
PostPosted: Fri Sep 23, 2011 2:08 pm    Post subject: Reply with quote
Dear Eng. Rajan,
Can you give me reference rom where I can download or purchase the handbook published by Tamilnadu PWD?
with thanks,
Aditya
PostPosted: Sat Sep 24, 2011 5:26 am    Post subject: PWD Mini Technical Hand Book-2011 Reply with quote
Dear Aditya,
This year Tamil Nadu PWD have released Mini Technical Hand Book-2011 (consolidated). The cost of book is Rs.300/ You can get it by courier/post from following address:
The Secretary-Publication,
Assistant Engineers' Association,
TamilNadu P.W.D.
Cheppakkam, Chennai-600 005.
Phone 044-2842345.
Thank you,
V.M.RAJAN.
thirumalaichettiar
PostPosted: Sat Sep 24, 2011 5:42 am    Post subject: Reply with quote
The references have already been posted in the Sefi forum long times back under the same topic and one has to take some pain to browse and find out rather than posting again.
The tel no. furnished by Egr. Rajan is not correct and the correct number is 044-28515445
T.Rangarajan.
PostPosted: Sat Sep 24, 2011 6:31 am    Post subject: Design of Two way slab with wall load Reply with quote
Procedure given by Er Mofiz Ahmed is generally followed .
Just to add that it would be appropriate if a factor of 1.5 may be multiplied to
the equivalent UD loading (worked based on total wall load/slab area)
to take care of concentration effect of partition load .
Is code 875 about light parttion loading indicate that partition loading
on slab as equiv UD ( in terms of Kg/m2) may be taken as 1/3rd of parttion
load (in Kg/m) .
This could also be checked and higher of the parttion loading from
two computations can be used in design.
best regds
vikramjeet
ibarua
PostPosted: Sat Sep 24, 2011 12:47 pm    Post subject: Design of Two way slab with wall load Reply with quote
Normal 0   false false false        MicrosoftInternetExplorer4  <![endif]-->   <![endif]-->  /* Style Definitions */ table.MsoNormalTable      {mso-style-name:"Table Normal";      mso-tstyle-rowband-size:0;      mso-tstyle-colband-size:0;      mso-style-noshow:yes;      mso-style-parent:"";      mso-padding-alt:0in 5.4pt 0in 5.4pt;      mso-para-margin:0in;      mso-para-margin-bottom:.0001pt;      mso-pagination:widow-orphan;      font-size:10.0pt;      font-family:"Times New Roman";      mso-ansi-language:#0400;      mso-fareast-language:#0400;      mso-bidi-language:#0400;}  <![endif]-->
24th Sept 2011
For a brick wall resting on a slab, it will be more accurate to calculate Mx and My from an equation derived from plate bending theory (see Timoshenko & Winowsky-Kreiger -- 'Theory of Plates & Shells'). We have developed a program for simply supported slabs. For slabs restrained at the edges, the problem is somewhat more complicated. However, we may safely use 80% of the sagging moment in simply supported slabs for designing slabs restrained at the edges.
Indrajit Barua.
Sent: Sat, 24 Sep 2011 12:19:55
Subject: [SEFI] Re: Design of Two way slab with wall load
load (in Kg/m) .
best regds
vikramjeet
Kumar_Abhishek_Singh
PostPosted: Mon Sep 26, 2011 12:00 pm    Post subject: Reply with quote
I think yield line analysis will give better results, for a slab with a line load.
Thank you,
Kumar Abhishek Singh
G.Manjunath
PostPosted: Mon Sep 26, 2011 1:56 pm    Post subject: Reply with quote
thanks everybody. Yes i also personally feel that yield line theory gives the better result. but i wanted to know any easy approximation solutions. I will try the methods explained from the seniors
Manju
Translation:
