SocialTwist Tell-a-Friend
Shear wall design using STAAD
Goto page 1, 2, 3, 4, 5  Next
PrachiThube
PostPosted: Fri Dec 05, 2008 11:03 am    Post subject: Shear wall design using STAAD Reply with quote
Dear All
               I am designing shear walled building using STAAD for the first time.I have modeled shear walls using plate element but I am unable to extract the result for design.
       I have attached a small STAAD file, will somebody elaborate with reference to attached file how to extract design values of   Pu, Mx and shear force for design?
Thanks in advance!
P. Thube
STAAD input file.zip
 Filename:  STAAD input file.zip
 Filesize:  6.11 KB
 Downloaded:  2694 Time(s)
Thankful People
venu
PostPosted: Fri Dec 05, 2008 12:04 pm    Post subject: Shear wall design using STAAD Reply with quote
Dear Thube
Exactly where you are getting the probem. I haven't get any problem to get the plate results.
Follow the steps below.
1. Run the analysis
2. Got post processing mode.
3. Select the plates which you want results.
4. Got the reports----plate results.....plate stress.
venu
--- On Fri, 5/12/08, PrachiThube <forum@sefindia.org> wrote:
Subject: [SEFI] Shear wall design using STAAD
Date: Friday, 5 December, 2008, 4:33 PM
Dear All
Thanks in advance!
P. Thube
Add more friends to your messenger and enjoy! Invite them now.
PrachiThube
PostPosted: Fri Dec 05, 2008 1:38 pm    Post subject: Shear wall design using STAAD Reply with quote
Dear Venu
We get Mx, My, Mxy (in kN-m/m), SQx, SQy (KN/sqmm)
How to calculate reinforcement from this?
P. Thube
struct_tech
PostPosted: Fri Dec 05, 2008 3:38 pm    Post subject: Shear wall design using STAAD Reply with quote
hi Prachi,
Kindly model the shear walls as surface element rather than plate element.(available in version 2007)
regards,
siddharth
On Fri, 05 Dec 2008 venu wrote :
Dear Thube
1. Run the analysis
venu
Dear All
Thanks in advance!
P. Thube
STAAD input file.zip (http://www.sefindia.org/forum/files/staad_input_file_198.zip)
Add more friends to your messenger and enjoy! Invite them now. (http://in.rd.yahoo.com/tagline_messenger_6/*http://messenger.yahoo.com/invite/)
Siddharth Subhedar
Arunbabu.S
PostPosted: Sat Dec 06, 2008 4:31 am    Post subject: Shear wall design using STAAD Reply with quote
Dear Mr. P. Thube
  1. First check the orientation of the plates in which every plate should be in same orientation and if it was correct the force flow will be proper.
  2. After analysis, extract results for the wall which you are designing. Staad will give results in the form of Mx, My, Mxy, SQx, SQy, Sx, Sy & Sxy.
  3. From the moments you design the reinforcement required for the wall.
  4. Check the provided reinforcement is sufficient from the stresses Sx, Sy & Sxy.
  5. Sx & Sy are the membrane stresses in X and Y direction.
  6. For Vertical reinforcement you check the stress Sy is less than 0.4 Fck, if it was less then provide minimum reinforcement of 0.12% of gross Area.
  7. For Horizontal reinforcement you check the stress Sx = Tv, which is shear stress along X dir. Check Tv < Tc for the provided vertical reinforcement. If Tv > Tc then provide suitable horizontal reinforcement for the stress, else provide minimum reinforcement of 0.2%.
  8. While designing be careful with the sign convention. (Tension +ve & Compression –ve)
Experts please correct me if there are any mistakes.
Arunbabu.S
Sent: Friday, December 05, 2008 4:34 PM
Dear All
Thanks in advance!
P. Thube
"This Message and its contents is intended solely for the addressee and is proprietary.Information in this mail is for L&T Business Usage only. Any Use to other than the addressee is misuse and infringement to Proprietorship of L&T ECC.If you are not the addressee please return the mail to the sender.L&T ECC DIVISION"
PrachiThube
PostPosted: Sat Dec 06, 2008 9:45 am    Post subject: Shear wall design using STAAD Reply with quote
Dear Sir
Thanks for answering my query! Laughing
I am attaching excel sheet of the plate analysis output and tried to
Calculate Pu, Mx, My And Vu.
Please let me know whether my approach is correct or not?
Shall I design the shear wall as biaxial bending column using interaction
Charts for calculated values of Pu, Mx, My (And Vu)?
Thanks Confused
P. Thube
PLATE ANALYSIS OUTPUT.zip
 Filename:  PLATE ANALYSIS OUTPUT.zip
 Filesize:  4.18 KB
 Downloaded:  1844 Time(s)
ajeetkokil
PostPosted: Sun Dec 07, 2008 8:20 am    Post subject: Shear wall design using STAAD Reply with quote
Dear Prachi
I am not sure whether your out of plane axis is X or Z. Whatever, it may be, say X, please equate moment of resistance of the plate w.r.t. steel i.e. (permissible tensile stress * area of steel * lever arm) and get the area of steel required. Rest of the stress parameters are required to check the plate agaist shear.
Hope this helps
Ajit
On Fri, 05 Dec 2008 PrachiThube wrote :
Dear Venu
P. Thube
Ajit Shankar Kokil
sudipnc
PostPosted: Tue Dec 09, 2008 6:03 am    Post subject: Shear wall design using STAAD Reply with quote
Hello P. Thube,
From the analysis point of view, there is no problem if you model the shear wall as plate elements. However, if you want the design of the shear walls as well, you need to model the shear wall as surface elements. A surface element is a collection of plate elements and the whole collection is treated as an entity for design. The plates are only designed for out-of-plane bending. I hope this helps.
Sudip
Dear All
Thanks in advance!
P. Thube
M.ANBARASU
PostPosted: Wed Dec 17, 2008 10:26 am    Post subject: Reply with quote
dear Mr. Dhube
while to design a shear wall by using staad pro. you can use surface elements to create shear wall.after analysing it. you can design by using only BS & ACI codes by using staad pro. staad is not supporting for IScode?
with regards
m.anbarasu
lecturer in civil engineering
Government college of engineering
salem-11
tamilnadu
9942509440
jagadeshkannan
PostPosted: Sat Dec 20, 2008 6:55 pm    Post subject: Re: Shear wall design using STAAD Reply with quote
struct_tech wrote:
hi Prachi,
regards,
siddharth
hi siddharth
wats the reason behind modeling shear wall as surface rather than plate
regrads
JK
Dear Thube
1. Run the analysis
venu
Dear All
Thanks in advance!
P. Thube
Siddharth Subhedar
Page 1 of 5
Translation:
