SocialTwist Tell-a-Friend
Staad Pro for mat foundation
venkatsuba
PostPosted: Mon Jul 19, 2010 7:36 pm    Post subject: Staad Pro for mat foundation Reply with quote
Dear Sefians
We have designed several mats which support as little as two pedestals, combinations of pedestals and shear walls, and even large mats with multiple columns and forces using Staad Pro with plate elements set to the thickness of the mat.  Foundation Springs were provided as per Modulus of Subgrade Reaction for the soils.  Loads added at support points (pedestals) and the analysis done.
The following were taken from the Staad out put for RC design:
1. Soil Bearing pressure - to confirm it is within the allowable SBC
2. Bending & Shear - for reinforcement requirement.
3. Displacement - to check allowable settlement
The punching shear & stability checks( Over turning & Sliding) were performed manually.
I kindly request the dear members to confirm whether this approach of design is correct or it has any flaws and advice the right approach. We don't have "Staad Foundation module" with us.
Subashini
sekharbrs
PostPosted: Tue Jul 20, 2010 9:02 am    Post subject: Reply with quote
The procedure followed seems OK.
I do not know how you are getting the Subgrade reactions, normal procedure is to give based on the "Bowles" formula "1000/(allowable settlement in mm) x safety factor (Generally 2/3/4) x SBC of soil" .
And one way shear along the length of the mat also shall be checked in some cases, where one side supports are more compared to the other or in the case of concentration of reactions is more compared to the other side.
Sekhar
taorigiriraj
PostPosted: Sat Jul 24, 2010 4:31 pm    Post subject: Staad Pro for mat foundation Reply with quote
Please confirm how you are checking SBC directly from staad.
--- On Tue, 7/20/10, venkatsuba <forum@sefindia.org> wrote:
Subject: [SEFI] Staad Pro for mat foundation
Date: Tuesday, July 20, 2010, 7:47 AM
Dear Sefians
Subashini
thirumalaichettiar
PostPosted: Sun Jul 25, 2010 1:04 am    Post subject: Reply with quote
Mat Foundation Design:
It is better to use STAAD foundation software which is a separate module.
Otherwise you can make use of SAFE from CSI since it is an easy to use and more versatile software for foundation design of Mat.
T.Rangarajan.
Aadhavan
PostPosted: Sun Jul 25, 2010 10:17 am    Post subject: Re: Mat Foundation Reply with quote
Dear Sirs
I have not used Staad Pro for modelling Mat / Raft Foundations till now and i am much interested to know about it. Kindly post me a sample model showing a structure designed with foundation springs and raft foundation. Also it would be very helpful if an example is given for shear wall raft model as well.
Thanks in advance
Aadhav
ajaymistry
PostPosted: Sun Aug 01, 2010 4:16 pm    Post subject: circular pile raft Reply with quote
Can anyone provide steps for inputting/analyzing/ designing Circular Piled raft foundation using Staad Foundation. ?
Eg: Raft thk= 4m and Dia=43.4m , 464 piles of 530mm dia (120ton capacity)
It is a raft for 220m tall RCC chimney.
vk.wits
PostPosted: Sun Nov 25, 2012 5:59 pm    Post subject: how to apply checks Reply with quote
please tell how to apply check for one way shear ........... i had deigned raft as per two way shear but can u please tell me the step by step check for one way shear
Translation:
