Supriya P SEFI Member
Posted: Wed Feb 04, 2009 6:46 pm Post subject: Expansion Gap & Shrinkage strip |
If the length of structure exceeds the permissible codal limit then expansion gap is provided. Please tell me whether temperature stresses can be catered by means of shrinkage strips.
In that case, please tell whether shrinkage strips are an alternative to expansion gaps & which is technically correct & viable
Senior Technocrats- Please advice.
Supriya
Posted: Wed Feb 04, 2009 11:13 pm Post subject: Expansion Gap & Shrinkage strip |
Hi,
shrinkage strips are employed as temporary joints to reduce shrinkage cracks in a multistory building.
P.S. See attached paper for more details
--- On Thu, 2/5/09, Supriya P <forum@sefindia.org> wrote:
Quote: | From: Supriya P <forum@sefindia.org>
Subject: [SEFI] Expansion Gap & Shrinkage strip
To: general@sefindia.org
Date: Thursday, February 5, 2009, 1:44 AM
Supriya
Shrinkage_and_Temp_Reinforcement-Suprenant-CI-2002.pdf |
67.13 KB |
2679 Time(s) |
mkalgal Silver Sponsor
Posted: Thu Feb 05, 2009 6:23 am Post subject: |
Dear Supriya,
As rightly mentioned by Dr. NS, shrinkage strip is different from Expansion joints. You may also look at my reply to Mr. Leakath under discussion title "Thermal Analysis for RC Buildings" posted on 28th Jan. 2009, where some more references are available
Dr. M. R. Kalgal
paravansefi SEFI Regulars
Posted: Thu Feb 05, 2009 11:13 am Post subject: Expansion Gap & Shrinkage strip |
Dear Supriya,
In my opinion, you cannnot consider the shrinkage strips as a substitute for expansion joint.
Shrinkage strips are only temporary and it do not caters to the long term effect(seasonal) of the temperature stresses.
To releive these either you have to provide expansion gaps or do the temperature analysis,
regards,
Aravan.
Supriya
