SEISMIC LOADING IN STAADPRO
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> Past Discussions Year 2003
dharikrishna
PostPosted: Thu Nov 27, 2003 4:05 pm    Post subject: SEISMIC LOADING IN STAADPRO Reply with quote
HI FELLOW MEMBERS OF THE FORUM
HI I WISH TO KNOW IF ANY ONE SUGGESTS ME HOW TO  DEFINE THE SEISMIC LOADING
IN STAAD PRO
I HAVE ANALYSED A 5 STORIED SHEAR FRAMED STRUCTURE USING STAADPRO
I GOT THE ANALYSIS RESULT FROM STAAD PRO
I WANT TO ANALYSE THE SAME FRAME USING RESPONSE SPECTRUM METHOD USING
STAADPRO
BUT I M UNABLE TO DEFINE THE SEISMIC LOAD CASE , SO PLEASE IF ANY ONE COULD
SUGGEST ME IN THIS REGARD .. THEN I WILL BE GREAT FULL TO U
THANKING U ALL
FELLOW SEFI MEMBER
_________________________________________________________________
bhumika
PostPosted: Mon Dec 01, 2003 5:24 am    Post subject: SEISMIC LOADING IN STAADPRO Reply with quote
Hello sir,
To apply "Response Spectrum" in STAAD Pro, the command line in text file of
staad is
SPECTRUM "MODAL COMBINATION" "DIRECTION" "FACTOR" "RESPONSE" DAMP ______
SCALE _______
T  RESPONSE ;
The above command line specifies that the modal responses can be combined
using either CQC method or SRSS method. The spectrum can be applied in
global X, Y or Z direction with some factor (usually 1.0). The "Response"
may be acceleration or displacement. Damping ratio is 0.05 (damping 5%) for
concrete structures. The scale factor is the quantity by which spectral
accelerations (and spectral displacements) must be multiplied by before they
are used in the calculations. The spectrum data is given as period vs.
acceleration.
Apply it after giving self-weight or dead load command.
For example,
As per IS 1893-2002 part 1, response spectrum ordinates in terms of T
(Natural period) and Acceleration for medium soil condition, structure
situated in zone 5 and for 5% damping is
0 0.54; 0.1 1.35
0.55 1.35; 1.0 0.73
1.5 0.49; 2.0 0.37
2.5 0.29; 3.0 0.24
3.5 0.21; 4.0 0.18
Command line for this spectrum is
LOAD 2 SEISMIC LOADING
SPECTRUM CQC X 1.0 ACC DAMP 0.05 SCALE 1.0
0 0.54; 0.1 1.35
0.55 1.35; 1.0 0.73
1.5 0.49; 2.0 0.37
2.5 0.29; 3.0 0.24
3.5 0.21; 4.0 0.18
In modeling mode
In "Commands" menu, go to loading,  primary load.
Define Load 2 as "seismic loading". Now load page will open. In that click
on spectrum and apply data as explained above.
Bhumika
Subject: SEISMIC LOADING IN STAADPRO
Date: 27/11/03
Time: 21:35:42
LOADING
IN STAAD PRO
STAADPRO
COULD
THANKING U ALL
FELLOW SEFI MEMBER
vva at vsnl.com
PostPosted: Wed Dec 03, 2003 12:18 pm    Post subject: SEISMIC LOADING IN STAADPRO Reply with quote
Dear Anand,
1. To simulate rigid diaphragm, you should use command
"SLAVE DIAPHRAGM ZX MASTER  (master joint number) JOINT (slave joints) "
You should not use master fx and fz command which will force the model to
have same displacements in x or z directions for all the floor joints.
2. Secondly, you will have different stiffness in x and z direction.
Accordingly, the base shear in x and z will be different. It generally
tallies with the hand calculations.
For more information you can refer to article in ISSE Journal Oct-Dec2001 on
this topic.
For STADD ENGINEERS Mumbai
Hemant Vadalkar
Consulting Engineer
Authorized Dealers for STAADpro, STAADetc, AutoCivil, Layout and eReview
software products since 1995.
STADD ENGINEERS, MUMBAI
118, Veena Beena Shopping Centre, Opp. Bandra Station(W), Mumbai 400 050
INDIA
Tel. / Fax : 91-22-2643 0668 / 91-22-2641 0857
Email : info@staadpro.com        Website : www.staadpro.com
mc.upadhyay1
PostPosted: Thu Dec 04, 2003 7:38 am    Post subject: SEISMIC LOADING IN STAADPRO Reply with quote
hello anand
STAAD does not calculate the time period as per
code formula (0.09*h/sqrt(d)) as you would be calculating.
although they say "define 1893 load".
So you have give the time period as calculated to get the
desired base shear.
Mukesh Upadhyay
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> Past Discussions Year 2003 All times are GMT
