Master-Slave etc.
rsmengr at eth.net
PostPosted: Wed Jan 21, 2004 4:12 am    Post subject: Master-Slave etc. Reply with quote
Dear Mukesh:
When you use master slave option you are introducing a constraint in your
model that the two ends of the beam can't move w.r.t. each other. So axial
forces will be zero (because of constraint in your model). That is the
reason STAAD is not printing them.
I must add here that the presence of large axial forces in horizontal
members (beams) must be recognised in a few cases like Arch-Tie sytems,
Virendeel Girders etc. In such cases you will have to use other modelling
options to capture Axial forces in beams.
Hope this helps
Rajiv Sharma
