Master-Slave etc.
rsmengr at eth.net
PostPosted: Fri Jan 23, 2004 4:58 am    Post subject: Master-Slave etc. Reply with quote
Mukesh:
When we use Rigid Diaphragm or Rigid Rod/Bar constraints at a floor we
neglect axial deformations in horizontal members connected with these
constrained nodes. So axial forces in such horizontal members will be output
as zero. This is the property of your model and not of the structure.The
fundamental assumption behind this must be understood clearly. I suggest you
to see book on Matrix Method of analysis by Gere and Weaver for a detailed
explanation.
Hope this helps
~Rajiv.
