Master-Slave option in STAADpro.
vva at vsnl.com
PostPosted: Fri Jan 23, 2004 3:21 pm    Post subject: Master-Slave option in STAADpro. Reply with quote
Dear Mukesh,
The agree with the reply given by Rajiv about the Master Slave option.
Due to simulation of rigid diaphragm action using master slave command, the
relative displacement between two joints of a beam is zero, hence you get no
axial force in the output. But at the same time this diaphragm ensures the
distribution of lateral loads to the columns in proportion to their
stiffness. The equilibrium is achieved by transferring the lateral forces to
columns through the rigid body.
If you want  to get the axial force in the beams and at the same time want
to simulate the diaphragm action, use very high value of IY for floor beams
and see the results.
With thanks and regards.
For STADD ENGINEERS Mumbai
Hemant Vadalkar
Consulting Engineer
STADD ENGINEERS, MUMBAI
118, Veena Beena Shopping Centre, Opp. Bandra Station(W), Mumbai 400 050
INDIA
Tel. / Fax : 91-22-2643 0668 / 91-22-2641 0857   Residence :Kirty
91-251-2471689
C-482, II floor, Vashi Plaza, Sector-17, Vashi, New Mumbai 400 705  Tel.
91-22-2789 5084
Email : info@staadpro.com        Website : www.staadpro.com
