malay.kumar at total-e... Guest
Posted: Tue Jan 27, 2004 6:51 am Post subject: Aanamika's solution |
Dear Ana, First go to the STAAD editor and try out these commands. I am giving you the basic commands by which you can generate a 3D Space Frame. I hope this 'll help you :
STAAD SPACE (File NAME) INPUT WIDTH 72 INPUT NODESIGN UNIT METER MTON JOINT COORDINATES ( FEED ALL THE COORDINATES) MEMBER INCIDENCES ( FEED ALL THE MEMBER PROPERTIES) MEMBER PROPERTY INDIAN (FEED ALL THE MEMBER PROPERTIES) CONSTANT E CONCRETE ALL DENSITY CONCRETE ALL SUPPORT (FEED SUPPORT CONDITIONS) MEMBER RELEASE (IF ANY AND IF REQUIRED)
LOAD 1 DL+LL SELFWEIGHT Y -1. MEMBER LOAD (Feed the member loading)
PERFORM ANALYSIS PRINT MEMBER FORCES ALL
FINISH
Regards Malay
________________________________________________________________
