Building Curve in Plan ! STAAD prob.
sankaran
PostPosted: Tue Jan 27, 2004 7:04 am    Post subject: Building Curve in Plan ! STAAD prob. Reply with quote
dear Mr malay
Please specify beta angle or meber reference point on local y axis of the
column in " constants ". regards
sankaran.s
malay.kumar at total-e...
PostPosted: Tue Jan 27, 2004 7:51 am    Post subject: Building Curve in Plan ! STAAD prob. Reply with quote
Dear Mr. Sankaran,
Suppose as for eg. the column is placed at 45 degrees w.r.t horizontal
x-axis (in plan)
Kindly let me know what'll be the full  command in such case !
Malay
________________________________________________________________
sankaran
PostPosted: Tue Jan 27, 2004 8:37 am    Post subject: Building Curve in Plan ! STAAD prob. Reply with quote
Dear Mr Malay
Suppose the column is designated as Member 23 say. if you are in edit input
command file
Then the typical command is to be input under Constants. that is
Constants
Beta 45 memb 23
If you are in Staad interactive input mode you can use memb const module to
generate the orientation.
You can also see examples,verification problems which are available with
Staad.
You can also see help module for required information on
constants,reference,beta etc.After beta angles are input verify the
orientation graphically
and by using 3D rendering and shading. Hope this meets your requirements.
For more clarity Please contact replmad@vsnl.com .Regards.
Sankaran
BANSALS
PostPosted: Tue Jan 27, 2004 9:04 am    Post subject: Building Curve in Plan ! STAAD prob. Reply with quote
Dear Malay,
In the recent STAAD.Pro version we can define the Beta angle. Try recent
version of STAAD.Pro.
Sanjay Bansal
Indian Oil Corporation Limited
-----Original Message-----
[mailto:malay.kumar@total-environment.com]
Sent: Tuesday, January 27, 2004 3:50 PM
To: BANSALS@iocl.co.in
Subject: Building Curve in Plan ! STAAD prob.
Hi All,
I am dealing with a project (RCC frame structure) - administrative block ,
which is curve ( rather semicircular ) in plan. Everything is fine except
one problem which I have encountered and I'm unbale to fix the problem.
While doing the Analysis in STAAD-III,  I am very well able to generate the
Structural Frame in it's actual profile (curved). But the point is I can't
feed the Columns in there actual profile. The Columns are neither parallel
to x-axis nor z-axis, rather there profile is such that they are placed in
30 - 60 degrees w.r.t either axis. All I want to know is that : is there any
command in STAAD-III , by which Columns can be placed in there actual
profile ? Not necessary always parallel or perpendicular to any of the axis.
I hope I am able to put my problem clearly , and expecting some replies at
the earliest.
Malay
Total Environment Building Systems Pvt Ltd, Bangalore, India
========powered by Reach1to1 Office
Everywhere
