Large dia.(>30m) RCC circular water tanks/&surat stor
s_n_surya at yahoo.com
PostPosted: Fri Jan 30, 2004 5:13 am    Post subject: Large dia.(>30m) RCC circular water tanks/&surat stor Reply with quote
DEAR SIRS
AS SAID EARLIER YU NEED PROTECTIVE COATING OUTSIDE ,TO
PROTECT WHEN EMPTY IN HOT SEASON AND NO EXPANSION
JOINTS.FORGET ABOUT IT HAPPILY ,OTHERWISE NO WATER
WILL BE STOED,OR ELSE USE PVC&OR RUBBER CONSTUCTION
JOINT MATERIALS WHICH SERVE BOTH PURPOSES. & THANK ME
AT LEAST ONCE IF YU ARE IN RIGHT SPIRIT WITH THIS.
AS FAR AS SURAT STORM WATER DESIGNS ,YOU NEED TEN
YEARS OF RECORDS MINIMUM,WITH SRORM WATER
INTESITY,TIME,SLOPE OF TERRAIN AND WATER ABSORTION BY
SOIL[SAY RUN OFF ,PRECEIPITATION,SUB SOIL FLOW AND
GRADIENT,AND WHERE SUB SOIL MEETS ANY ABOVE GROUND
WATER]
THAT MEANS CONTOURS ON GROUND,SUB WATER SURFACE AND
MINIMUM 25 YEARS RECORDS.
BYE SURYA
--- hsnagle@vsnl.net wrote:
[quote]I THINK BY CATERING FOR TEMPERATURE STRESSES, U CAN
DESIGN THE TANK WITH
EXPANSION JOINT.
ONE MORE POIN IN THIS REGARD -
IF IT IS WATERTANK, YOU WILL NOT HAVE TEMPERATURE
VARIATION AS WATER IS IN
CLOSE VICINITY.
H.S.NAGLE(DINESH)
