Large dia. RCC circular water tanks
ranna
PostPosted: Sat Jan 31, 2004 10:29 am    Post subject: Large dia. RCC circular water tanks Reply with quote
If it is below ground level temp stresses need not be taken into account.
r.annathurai
trichy
gupta@mehtalia.com wrote:
[quote]Dear Malay,
What if it happens to be ground water tank ?
Thanking you,
(B. J. Gupta)
Subject: Large dia.(30m) RCC circular water tanks
Date: 29/01/04
Time: 15:42:58
Dear Gupta,
What I think ( but I am not sure , you can check and verify ) that it is
possible to design a Over head Water Tank whose wall perimeter exceeds 45
mts.
What I think that Expansion joints are required for those structures which
are having free ends. And hence water tank walls are considered to
be enclosed and not having any free ends so we can ignore the possibility
of
providing Expansion joints and very well design for hoop action etc.
Malay
________________________________________________________________
gupta
PostPosted: Mon Feb 02, 2004 8:00 am    Post subject: Large dia. RCC circular water tanks Reply with quote
Dear Mr Annathurai
Tank is 750 mm below ground level and 5500mm above ground level.
Thanking you,
(B. J. Gupta)
Subject: Large dia. RCC circular water tanks
Date: 31/01/04
Time: 15:59:40
r.annathurai
trichy
Dear Malay,
Thanking you,
(B. J. Gupta)
Subject: Large dia.(;#62;30m) RCC circular
water tanks
Date: 29/01/04
Time: 15:42:58
Dear Gupta,
that it is
exceeds 45
mts.
structures which
considered to
possibility
of
action etc.
Malay
[quote]
gupta
PostPosted: Mon Feb 02, 2004 8:07 am    Post subject: Large dia. RCC circular water tanks Reply with quote
Dear sir,
I doubt if water bar will act as expansion joint if reinforcement is continued across the joint.
Thanking you,
(B. J. Gupta)
[quote]Subject: Large dia. RCC circular water tanks
Date: 31/01/04
Time: 18:32:30
DEAR SIRS
I THINK THAT I REPILED THAT WATER BAR OF -PVC-OR
RUBBER -WITH CENTRAL BULB ACTS AS  1]EXPANSION AND
CONSTRUCTION JOINT.
WE DID AT LEAST HALF A DOZEN TANKS IN LAST 15 YEARS
WITH SAME PHENOMENON AND THEY ARE STILL SAFE. PLEASE
LET ME KNOW IF I AM WRONG ALSO
SURYA
--- gupta@mehtalia.com wrote:
Dear Malay,
Thanking you,
(B. J. Gupta)
Date: 29/01/04
Time: 15:42:58
Dear Gupta,
mts.
are considered to
of
Malay
malay.kumar at total-e...
PostPosted: Tue Feb 03, 2004 5:35 am    Post subject: Large dia. RCC circular water tanks Reply with quote
Dear Mr. Gupta!
I'll rather stick to my opinion. As I told you before also what I think it's
not absolute necessary to provide an Expansion joint for and enclosed
Structure like Circular water tank , coz' it's not having any free end to
expand or to contract.
I am not sure thou , but I think I have a point - still awating replies and
satisfactory answers from some Experts in this field.
Malay
s_n_surya at yahoo.com
PostPosted: Tue Feb 03, 2004 10:08 am    Post subject: Large dia. RCC circular water tanks Reply with quote
DEAR SIRS
I think i expressed the need for continueous concrete
.this is possible only when concrete is pumped.
still it is better to have water bar of 230 mm wide of
pvc or rubber ,which served both purposes ,in many
cases.
surya
--- malay.kumar@total-environment.com wrote:
Dear Mr. Gupta!
for and enclosed
field.
Malay
[quote]
gupta
PostPosted: Thu Feb 05, 2004 11:02 am    Post subject: Large dia. RCC circular water tanks Reply with quote
Dear Malay,
Foundations of circular taks may not be totally free to expand along with wall. Hence don't you there will be thermal stresses in the walls due to change in ambient temperature.   My this querry didn't appear in  today's daily digest hence repeating the same.
Thanking you,
(B. J. Gupta)
Date: 03/02/04
Time: 11:05:13
Dear Mr. Gupta!
think it's
end to
and
[quote]satisfactory answers from some Experts in this field.
Malay
PostPosted: Thu Feb 05, 2004 12:17 pm    Post subject: Large dia. RCC circular water tanks Reply with quote
Dear Mr. Gupta Smile Now that you have answered your own question - If the tank
is NOT  totally free to Expand then there is no need to provide Expansion
joint. And you have rightly pointed it out that there'll be some thermal
stresses in the walls due to change in temperature (specially when the tank
is empty) - and in such case the walls can be designed accordingly catering
for those thermal stresses ! Personally I haven't designed such huge water
tanks which are 1/4'th below ground and remaining above , but then you can
refer some good Books regarding this interesting & challenging design !! If
I come across some Good books regarding your querry I'll definitely let you
know.
By the way can anyone suggest me a good book for design and detailing of a
complete Spiral Staircase with a Stringing Beam in between . Pls. note that
there is not a single intermediate support in between i:e : the angle of
rotation - of the staircase - between two supports is 360 degrees. I have
gone thru many books which gives design chart for such spiral staircase but
those are with intermediate supports.
Best Wishes
Malay
