pipe rack with a steel platform
AMIT DUTT
PostPosted: Fri Feb 26, 2010 4:19 pm    Post subject: pipe rack with a steel platform Reply with quote
Dear SEFI members ,
I am designing a  steel pipe rack that is in continuation with an existing pipe rack. . Now I have to hang a  rectangular shaped operating platform (500kg/m2 live load) from the longitudinal tie beam & main framing beam.
The operating platform Top of grating is 500mm below the longitudinal & the main framing beams . Is it advisable to hang the platform from the pipe rack ?
The pipe rack is of a  small height of 2.5m only ( single tier) . Column/Frame spacing is kept at 3m (to match spacing of an existing pipe rack ) .The width of pipe rack is 2.2m only.
due to space restriction I do not want to take seperate columns for the operating platform ,it will be too close to the column of the pipe rack ( I want to avoid weird shaped combined foundation also since to present the design will  problematic
With Regards
AMIT DUTT
B.E.(CIVIL)
M.Tech.(STRUCTURES)
