mohandce SEFI Member
Posted: Mon May 31, 2004 11:38 am Post subject: details of Composite Structures |
”Dear Sefians! Any one help me to have / give the details of buildings Constructed by Using COMPOSITE STEEL-CONCRETE STRUCTURES IN INDIA?
by MOHAN
nycindia at vsnl.net Guest
Posted: Mon May 31, 2004 4:49 pm Post subject: details of Composite Structures |
DEAR FELLOW Er. MOHAN, ABOUT A YEAR BACK I SAW ONE SUCH RESIDENTIAL BUILDING IN PUNE HAVING STEEL FRAME AND PROBABLY RCC SLABS HAVING 4 FLOORS. IF YOU ARE INTRESTED THEN I CAN GET YOU THE NAME OF ARCHITECT/STRUCTURAL ENGINEER/OWNER THERE IS ONE FAMOUS BUILDING [MOST PROBABLY 10+ STORIED IN AHMEDABAD THE DETAILS CAN BE HAD FROM ANY MEMBER RESIDING IN A'BAD
WITH BEST WISHES N. Y. CHOUDHARY ----- Original Message ----- Message From <mohandce@iitr.ernet.in> To: <nycindia@vsnl.net> Sent: Monday, May 31, 2004 4:59 PM Subject: details of Composite Structures
Quote: | Dear Sefians! Any one help me to have / give the details of buildings Constructed by Using COMPOSITE STEEL-CONCRETE STRUCTURES IN INDIA?
by MOHAN
nil_nipul SEFI Member
Posted: Tue Jun 01, 2004 8:26 am Post subject: details of Composite Structures |
Hello, There is a one building in Ahmedabad. It is Steel-Concrete composite building.Designer is R.G.Desai. And constructed by Sunderdip builders and construction work is almost completed and site engineer is Ravi sonawala sir.Contact Ph No. is (079)26566110.
Address:-
501,"Sapphire" complex,C.G.Road,Ahmedabad-380006,Gujarat.
U can talk with Rajeshbhai Vaswani.
Regarding this building, it is constructed by castelled beam and column having channel section. No benifit of slab is taken in steel beam stiffness. So, it we consider stiffness wise buildng is just steel building. Concrete is provided around the steel section just for the fire resistance not to increase the strength of section.
I had designed one G+10 building having Steel-Concrete composite option.
By, Nipul patel
mohandce@iitr.ernet.in wrote: Dear Sefians! Any one help me to have / give the details of buildings Constructed by Using COMPOSITE STEEL-CONCRETE STRUCTURES IN INDIA?
by MOHAN
