column foundation joint
kirtesh_gandhi at hotm...
PostPosted: Tue Aug 17, 2004 8:22 am    Post subject: column foundation joint Reply with quote
Dear Mr. Barua,
The fixed base footing means that all its rotations are prevented which
further cause moments at the base.  The rotation required to reduce the
fixed base moment to zero is much smaller than that may occur when normal
settlement takes place in the subgrade.  It is very difficult to predict the
behaviour of subgrade and its effect upon the restraint at the base hence it
is more reasonable and safer to assume the base is hinged than fixed.
But the joint can be considered as fixed or partially fixed in rocky strata
or if better understanding of soil strata is available.
Hope it helps.
Kirtesh Gandhi
(Dalal Mott MacDonald)
[quote]Message From  <ibarua@deguild.com>
Reply-To: <general@sefindia.org>
To: <kirtesh_gandhi@hotmail.com>
Subject: Daily Digest Wed Aug 11 23:00:02 2004
Date: Sun, 15 Aug 2004 08:33:19 +0530
15 August, 2004
I do not understand what is meant by 'even
the slightest rotation destroys the moment'. I do not think that the
column-foundation joint can be considered as pinned.
Indrajit Barua.
On Wed, 11 Aug 2004 general@sefindia.org wrote :
mc.upadhyay1
PostPosted: Tue Aug 17, 2004 10:35 am    Post subject: column foundation joint Reply with quote
Hello
Assuming the column base as pinned is O.K.
but it will increase the time period of the structure thus
reducing the seismic forces.
Mukesh Upadhyay
kirtesh_gandhi@h
otmail.com               To:      mc.upadhyay@jil.co.in
cc:
08/17/04 01:43           Subject: column foundation joint
PM
Please respond
to general
Dear Mr. Barua,
the
it
Hope it helps.
Kirtesh Gandhi
roark.sol1
Diamond Sponsor
Diamond Sponsor
PostPosted: Tue Aug 17, 2004 3:36 pm    Post subject: column foundation joint Reply with quote
How would it matter, as the codal values anyway have an upper bound (approx
half the value obtained dynamically) for the time period !!
Pankaj
