DG Set foundation
snehal.bhatt at mottma...
Guest
PostPosted: Tue Aug 17, 2004 10:02 am    Post subject: DG Set foundation Reply with quote
Dear friends,
We have encoutered a problem in DG set foundation block: The details are as under:
1. There are 5 simillar DG sets with same details of foundation block at the same location:
2. In one of the DG set, there are vibrations and due to that there are lot of problems in DG set operation and were compelled to detatch DG set from foundation.All other DG sets are OK.
3. There is no visible crack in the foundation block.However some cracks are found in the grout of the foundation bolts at the corners.There are 8 bolts in each side and other pockets are OK.
Can anyone suggest the cause/ remedy for this type of vibrations?
JVCSNL
PostPosted: Wed Aug 18, 2004 11:48 am    Post subject: DG Set foundation Reply with quote
Dear Snehal,
It is difficult to judge the cause of the vibration problem in one of
the DG set foundation based on the information provided.  However,
assuming the same quality of reinforced concrete for all 5 foundation
blocks,  verify following conditions to assess the reason for the
vibration problem.
1.  At a first glance, I guess, the problem could be the misalignment
of the rotating parts of the DG showing vibration problem.  This may
induce larger Unbalance forces, leading to larger amplitudes.
Also, can you check whether all DG Sets are operating at the same
speed?  This information may guide you to assess the resonance criteria
at the operating speed (I guess it may be different from normal
operating speed for other DGs) which may not have been considered in the
Dynamic analysis of the block foundation.
2.  Though, the foundation block size for all DG sets is same, the soil
beneath each block may not have same properties.  Hence, if the soil
properties below each foundation vary from one block to other, the
performance of block foundation will also be different.
You may have to carry out detailed analysis to examine the causes of
the problem based on the machine's actual operating conditions, in-situ
soil and reinforced concrete properties.
Jignesh Chokshi
snehal.bhatt@mottmac-india.com 17-08-2004 >>>
Dear friends,
are as under:
Snehal.
JVCSNL
PostPosted: Wed Aug 18, 2004 12:21 pm    Post subject: DG Set foundation Reply with quote
Dear Snehal,
vibration problem.
Jignesh Chokshi
Dear friends,
are as under:
Snehal.
JVCSNL
Dear Snehal,
vibration problem.
Jignesh Chokshi
Dear friends,
are as under:
Snehal.
