Daily Digest Thu Aug 19 23:00:03 2004
ibarua
PostPosted: Fri Aug 20, 2004 2:15 am    Post subject: Daily Digest Thu Aug 19 23:00:03 2004 Reply with quote
20 August, 2004
Re.: Shaft supported tanks
The problem would appear to be the joint between the shaft and the tank body. A design could be adequate but the structure could still fail because of poor workmanship. Our supervising engineers and even engineers employed by contractor rarely go to the top of the structure to inspect formwork, rebars and even the concreting itself. All work at these heights and levels is done entirely by mistries and labourers. The result is poor workmanship, distress and failure. Otherwise, why should a tank fail under gravity loads without help from an earthquake?
I have avoided shaft type tanks in my practice beacuse of these reasons.
Indrajit Barua
Guwahati, Assam.
(ibarua@deguild.com)
On Thu, 19 Aug 2004 general@sefindia.org wrote :
[quote]---------------------------------------------------------
adsars
PostPosted: Fri Aug 20, 2004 3:26 am    Post subject: Daily Digest Thu Aug 19 23:00:03 2004 Reply with quote
Hello Ms Snehal Bhatt,
Besides the likely mechanical irregularity of rotating
parts as discussed before, I feel that it could be due to
the following possibilities -
- There may be play in anchor bolts and generator casing due
to improper alignment of anchor bolts during casting.
- The threds of anchor bolt are prone to wear out due sustained
exposure to larger vibrations.This leads to increase in vibrations.
- Also the level difference between various bolts could add to
this problem.
Towards the solution for this, following may be of use,
- Grouting the bed block where cracks appear.
- Isolating the foundation from undesirable vibrations by use of
packings like NEOPRINE pads or any other suitable measures.
[quote]----------------------------------------------------------
Message From  cdeshpan@yahoo.com
Subject: Re: DG Set foundation Daily Digest Wed Aug 18 23:00:02 2004
Date: 19/08/04
Time: 01:50:48
Hi Snehal,
Would you be able to let us know the approx. size and
pattern of cracks if possible, and also the kind of
grout that has been used.  Also how long has the
foundation been in service?  Also, if there is any
significant temperature differential possible, and any
other relevant details you may observe/know.  For
example: you have observed vibrations in one set, then
any available measurements of the same.
-Chitra
Message From  JVCSNL@ltecd.ltindia.com
Subject: DG Set foundation
Date: 18/08/04
Time: 17:18:46
Dear Snehal,
It is difficult to judge the cause of the vibration
problem in one of
the DG set foundation based on the information
provided.  However,
assuming the same quality of reinforced concrete for
all 5 foundation
blocks,  verify following conditions to assess the
reason for the
vibration problem.
1.  At a first glance, I guess, the problem could be
the misalignment
of the rotating parts of the DG showing vibration
problem.  This may
induce larger Unbalance forces, leading to larger
amplitudes.
Also, can you check whether all DG Sets are operating
at the same
speed?  This information may guide you to assess the
resonance criteria
at the operating speed (I guess it may be different
from normal
operating speed for other DGs) which may not have been
considered in
the
Dynamic analysis of the block foundation.
2.  Though, the foundation block size for all DG sets
is same, the soil
beneath each block may not have same properties.
Hence, if the soil
properties below each foundation vary from one block
to other, the
performance of block foundation will also be
different.
You may have to carry out detailed analysis to examine
the causes of
the problem based on the machine's actual operating
conditions, in-situ
soil and reinforced concrete properties.
Jignesh Chokshi
snehal.bhatt@mottmac-india.com 17-08-2004 >>>
Dear friends,
We have encoutered a problem in DG set foundation
block: The details
are as under:
1. There are 5 simillar DG sets with same details of
foundation block
at the same location:
2. In one of the DG set, there are vibrations and due
to that there are
lot of problems in DG set operation and were compelled
to detatch DG
set
from foundation.All other DG sets are OK.
3. There is no visible crack in the foundation
block.However some
cracks are found in the grout of the foundation bolts
at the
corners.There are 8 bolts in each side and other
pockets are OK.
Can anyone suggest the cause/ remedy for this type of
vibrations?
Snehal.
New and Improved Yahoo! Mail - Send 10MB messages!
Message From  ishacon@vsnl.net
Subject: Preservation of Structural Drawings and Data
Date: 19/08/04
Time: 12:11:41
In the USA it was a standard practice to keep the dox handy
for about 4 to 5 years after the project is completed.
Thereafter all the data would be transferred to micro-film.
I guess now with the IT revolution CD's are a better option, maybe.
But what if the CD gets corrupted !
I believe the Architects here normally keep the dwgs
available for 7 to 8 years.
V.P.Agarwal
ishacon@vsnl.net
