class 4.6 bolts
v.goel
PostPosted: Fri Oct 08, 2004 7:59 am    Post subject: class 4.6 bolts Reply with quote
Dear sefians
What is significance of 4 & 6 in class 4.6 bolts.
Virender Goel
Robert.Nicolson at Sub...
PostPosted: Fri Oct 08, 2004 9:28 am    Post subject: class 4.6 bolts Reply with quote
Virender,this notatation roughly means :-
4 - 400N/mm2 ( minimum tensile strength )
6 - 0.6 of 400 = 240N/mm2 ( min yield stress )
This notation applies to all the other bolts, e.g. :-
Grade 8.8, 10.9, or 12.9 e.t.c.
Thanks, Rob.
-----Original Message-----
Message From  v.goel@eil.co.in [mailto:v.goel@eil.co.in]
Sent: 08 October 2004 14:29
To: Robert Nicolson
Subject: class 4.6 bolts
Dear sefians
Virender Goel
========powered by Reach1to1 Office
Everywhere
Rudra Nevatia
PostPosted: Fri Oct 08, 2004 9:48 am    Post subject: class 4.6 bolts Reply with quote
Dear Virender,
The integer part multiplied by 100 gives fu of bolt in N/mm2 and fy is given
by decimal part multiplied by fu. So grade 4.6 bolt has fu = 400 N/mm2 and
fy = 0.6*400 = 240 N/mm2
Rudra Nevatia
--- v.goel@eil.co.in wrote:
Dear sefians
Virender Goel
_______________________________
Declare Yourself - Register online to vote today!
http://vote.yahoo.com
ssraman
PostPosted: Fri Oct 08, 2004 9:53 am    Post subject: class 4.6 bolts Reply with quote
Dear Goel,
In class 4.6 bolts, the first number is one tenth of the minimum UTS in
Kg/sq. mm, while the product of the numbers gives the minumum yield
stress in Kg/ Sq. mm. In this case UTS = 40 Kg/sq.mm and yield stress is
24 Kg/sq.mm.
S. Seetharaman
Dear sefians
Virender Goel
