220 Kg Cement M35 Ff 6.5 wow great !
sidhudaljeet
PostPosted: Mon Oct 18, 2004 2:32 pm    Post subject: 220 Kg Cement M35 Ff 6.5 wow great ! Reply with quote
Dear Jayant Lakhlani
Please explain the specifications followed for such type of work
Is there any other specification for such type of work
Because IRC 15:2002 “Standard Specifications and Code of Practice for Construction of concrete Roads” recommends minimum 350 Kg of Cement Per Cum of Concrete.
And further your flexural strength 6.5 MPA is also far more than the established relation that is as per IS 456 F Flex =0.7 ÖF ck  and as per IRC 15  Fc=7.63Ff+2.58. I am also doing lot of work in concrete pavement work the I doubt there could be some Calculation or Testing procedure mistake. If it is not there then your work is really appreciable.
Daljeet Sidhu
Rabinder Shekher
PostPosted: Mon Oct 18, 2004 4:29 pm    Post subject: 220 Kg Cement M35 Ff 6.5 wow great ! Reply with quote
Daljeet Sidhu
Dear Dalgeet,
Plz refer Editorial of ICJ sept. 2004 issue, "Concrete pavements:Some key issues"The editor has clarily indicated that there is sufficient lab. and field data test reports which suggest that if blended cement is used in place of OPC or supplementary cementitious material like fly ash or ground-granulated blast furnance slag as a part replacement of OPC, both the 90 day  stength and the %age gain in the stength attained between 28 to 90 days would higher. You can also refer Rigid pavement construction technology-recent experience of Mumbai- Pune express, Workshop on concrete in urban areas ICI Mumbai 08/2003 by Kulkarni,V.R, Momin,S.S and Bongirwar P.L.
with regards
Er. Rabinder Shekher
Jayant Lakhlani
PostPosted: Tue Oct 19, 2004 12:28 pm    Post subject: 220 Kg Cement M35 Ff 6.5 wow great ! Reply with quote
Dear Daljeet,
The only critical specification was that for w/c ratio. We are using w/c ratio as low as 0.36 and stringent quality control is being excercised on the site to maintain the same.
Due to very low w/c ratio, superplasticiser is being used to achieve the required workability. That is all.
The standards you have mentioned are for the concrete made with OPC. And I believe that high volume fly ash concrete is not included in any of them. So, when the standards are prepared for the same, we might find the formula giving flexural strength of 6.5 Mpa for M35 grade of concrete.
What I have mentioned are the real laboratory test results for the cubes and beam specimens and not derived from any formula giving the relation between the compressive strength and flexural strength.
-Jayant
Daljeet Sidhu
