Static Loading Vs Dynamic Loading
simran_shahani
PostPosted: Wed Oct 20, 2004 10:04 am    Post subject: Static Loading Vs Dynamic Loading Reply with quote
In all problems in Dynamics we have the inertial force coming into the picture as the body is in motion. My question is that , even in a static problem , say a cantilever beam subjected to a concentrated load "W" at the free end, won't this inertial force  also act , as the free end displaces from "0" to "Wl3 / 3EI" ??
Indiatimes Email now powered by APIC Advantage. Help!
gparsons at Structural...
PostPosted: Wed Oct 20, 2004 10:06 am    Post subject: Static Loading Vs Dynamic Loading Reply with quote
wYour message could not be delivered. The User is out of space. Please try to send your message again at a later time.
PostPosted: Wed Oct 20, 2004 12:12 pm    Post subject: Static Loading Vs Dynamic Loading Reply with quote
PostPosted: Wed Oct 20, 2004 1:44 pm    Post subject: Static Loading Vs Dynamic Loading Reply with quote
PostPosted: Wed Oct 20, 2004 4:06 pm    Post subject: Static Loading Vs Dynamic Loading Reply with quote
mc.upadhyay1
PostPosted: Thu Oct 21, 2004 11:32 am    Post subject: Static Loading Vs Dynamic Loading Reply with quote
Hello
Only when a body is subjected to some acceleration then it is acted
upon by an inertial force.
when a load is put it displaces the member from zero to a some value but it
does not cause
acceleration of the member.
Mukesh Upadhyay
simran_shahani@ind
iatimes.com                To:      mc.upadhyay@jil.co.in
cc:
10/20/04 04:09 PM          Subject: Static Loading Vs Dynamic Loading
Please respond to
general
HelpClick on the image to chat with me
JVCSNL
PostPosted: Thu Oct 21, 2004 2:42 pm    Post subject: Static Loading Vs Dynamic Loading Reply with quote
Hello Simran,
In the example you cited, the deflection of cantilever beam is due to
force applied at free end.  Note that, the deflection value is not
changing rapidy with time and hence, rate of change of displacement
(Velocity) and further,  rate of change of velocity (Acceleration) is
almost zero.  The deflection at free end is almost same all the time as
long as the load is acting at free end.  The variation of deflection
along the span is due to the bending stiffness of the member and does
not change significantly with time and can not be considered as the body
in motion.  For a body to be considered in a motion, the displacement
should vary rapidly with time.
In the problems of dynamics, the displacement at any point within the
body varies with respect to time (due to vibrating condition), hence the
acceleration will be non-zero value.    Note that, the inertial force
will be generated due to the non-zero acceleration produced during
vibration condition based on the mass acting during vibration.
In summary, in the static loading, the load and displacement does not
vary much with respect to time and does not produce time varying
effects.  Whereas in dynamic loading, load or displacement or both are
likely to vary significantly with time producing motion of the body.
Hope this clarifies the difference between static and dynamic loading.
Jignesh Chokshi
Disclaimer: This e-mail and any files transmitted with it are intended
solely for the use of addressee(s) only and may contain confidential
and/or privileged information. Any view or opinion presented in the said
e-mail is solely those of the author and do not necessarily represent
those of L&T - Sargent & Lundy Limited. If you are not the addressee,
then this message is not intended for you and be advised that you have
received this e-mail in error and that any use, dissemination,
forwarding, printing or copying of this e-mail is strictly prohibited.
In such case, please notify to the sender and delete the e-mail and any
attachments with it from your system immediately. Receipt of this e-mail
by you shall not give raise to any liability on the part of L&T -
mc.upadhyay@jil.co.in 21-10-2004 >>>
Hello
acted
but it
does not cause
Mukesh Upadhyay
simran_shahani@ind
iatimes.com                To:
cc:
Please respond to
general
static
the
displaces
