Robert.Nicolson at Sub... Guest
Posted: Wed Nov 24, 2004 11:16 am Post subject: A simple question about steel section properties |
ØCan someone plese tell me whether an angle, i.e. a L shape has a plastic neutral axis. Because I have just used a program which gave me Zpl,x & Zpl,y ( second moment of areas ), as both equal to 0, for an angle ?
Rudra Nevatia ...
Posted: Thu Nov 25, 2004 9:41 am Post subject: A simple question about steel section properties |
Intutively, for an equal leg angle, plastic neutral axes should be located close to the legs.
Rudra Nevatia
--- Robert.Nicolson@Subsea7.com wrote:
Quote: | Can someone plese tell me whether an angle, i.e. a L shape has a plastic neutral axis. Because I have just used a program which gave me Zpl,x & Zpl,y ( second moment of areas ), as both equal to 0, for an angle ?
__________________________________
http://mobile.yahoo.com/maildemo
kalyan SEFI Member
Posted: Fri Nov 26, 2004 4:18 am Post subject: A simple question about steel section properties |
Plastic neutral axis are calculated by equating total area in tension to be equal to the total area under compression about the two principal axes, which in the case of equal angles are UU nad VV axes.
Kalyanaraman
rudra_nevatia@yahoo.com wrote:
Quote: | Intutively, for an equal leg angle, plastic neutral axes should be located close to the legs.
Rudra Nevatia
