need help
amit_sharma
Progressive Member
Progressive Member
PostPosted: Sat Dec 11, 2010 3:54 am    Post subject: need help Reply with quote
Hello. I need a help for designing of foundation where the water is practically comes out from ground level after some excacation. The structure is B+G+3 storey and the approx area is 1800 Sq-feet. What should i do with this kind of structure. Please Suggest me.
umeshrao
PostPosted: Mon Dec 13, 2010 11:06 am    Post subject: Re: need help Reply with quote
     Dear Amit,
     Normally if water starts oozing from bottom of excavated pit and makes ground marshy, then use stone or bricks as soling material. Place the soling material in the pit and ram it until the material does not penetrate into ground and form hard surface. Lay pcc over the soiling material and proceed with the normal work.
     Other normal practice is pump out the water from pit to drain away from excavated area.
     Regards Umesh Rao
amit_sharma
Progressive Member
Progressive Member
PostPosted: Tue Dec 14, 2010 3:17 am    Post subject: thanks Reply with quote
Thank you so much sir..This information is much more helping for me.
