Help needed/Eigenvalue
sikandarsiddiqi
PostPosted: Tue Dec 07, 2004 10:13 am    Post subject: Help needed/Eigenvalue Reply with quote
SEFI offers you a whole new dimension for approaching issues of concern. Whenever you need quality inputs, the combined resource of SEFI members would be a useful sounding board - SEFI
In GOD we trust - Help us Lord - You are the Omnipotent
Dear Engr.Ajay,> City & Country location not mentioned
I am giving below information,each topic is clickable i.e move the mouse-arrow to the topic and click, pertinent to your requirement from our office record which may be of help to you:
MR Hatch, Consulting Mechanical Engineer - Downloads ...
... readability (my apologies to tight "c" code programmers ... ANSYS eigenvalue/eigenvector
results are converted to MATLAB ... using the following MATLAB extraction codes ...
hatchcon.com/documentation.html - 16k - Cached - Similar pages
comp.soft-sys.matlab February 1998
... in Real-Time 21 Feb 1998 12 LARGEST EIGEN VALUE!!!! ... 11 Feb 1998 1 Texture feature
extraction matlab code 11 ... 11 Feb 1998 2 compiling rtw generated c code on DSP ...
mathforum.org/epigone/comp.soft-sys. matlab?in=early&from=1998-02-01&to=1998-02-31 - 66k - 5 Dec 2004 - Cached - Similar pages
[PDF] PII: S0378-1119(01)00776-4
File Format: PDF/Adobe Acrobat - View as HTML
... Our own C-code was written implementing the NIPALS (nonlinear ... between zero and one,
where a value close to ... first princi- pal component (PC1, eigenvalue 3:1 ...
homepage.mac.com/fad1/Mcfadden_Papers/ 2001/Zuegge_neural_net.pdf - Similar pages
[PDF] Multiple motion analysis: in spatial or in spectral domain?
... He further introduced an eigenvalue-based coherence measure to distinguish different ...
basis using eigenvector analysis or singu- lar value decomposition (SVD). ...
www.ks.informatik.uni-kiel.de/ modules.php/name+Downloads,d_op+getit,lid+951 - Similar pages
[PDF] sdfsf sf
... of linear algebraic equations and Eigen value problems Direct ... Iteration methods
eigen values and eigen vectors Jacobis ... PTH. 7. Extraction of lipids ...
www.bdu.ac.in/syllabus/pha9-0.pdf - Similar pages
[PDF] Aaron Wallack Cognex Corporation Vision Drive Natick MA USA ...
... of Matlab routines for numerically solving the eigenprob lem and C code generation
routines ... of all common solutions can be reduced to an eigenvalue prob lem In ...
portal.acm.org/ft_gateway.cfm?id=281626& type=pdf&dl=GUIDE&dl=ACM&CFID=11111111&CFTOKE... - Supplemental Result - Similar pages
[PDF] 2002grc148 Mechanical and e-Engineering Technologies - Niskayuna
... frequencies and mode shapes using this approach is significantly more efficient
than the full system since the eigenvalue/eigenvector extraction is performed ...
www.crd.ge.com/cooltechnologies/pdf/2002grc148.pdf - Similar pages
[PDF] An Analytical Approach for Dynamic Range Estimation
... available, and which may be difficult to extract from C code. ... The eigen- functions
are also known to be orthonormal ... E[] is the mean or expected value operator ...
www.eecg.toronto.edu/~najm/papers/dac04-binwu.pdf - Similar pages
[PDF] Multidimensional Dipolar Exchange-Assisted Recoupling Measurements ...
... The eigenvector corresponding to the k 2I 1 eigen- value possesses in this limit
all coefficients equal to 1/ 2I 1. Therefore the probability matrix elements ...
www.weizmann.ac.il/chemphys/ Frydman_group/Publications/paper25.pdf - Supplemental Result - Similar pages
With best wishes.
Engr.Sikandar Hayat Siddiqi
Project & Seismic Design Management Engineer
Co-ordinator,Earthquake Anti-disaster Defence Management System Initiative (EADMSI)
Dhaka - Bangladesh/Asia
Radio Link International E-mail
-----------Original Message---------
