How to assign design parameters for Single Angles??
siddjubce
PostPosted: Thu Mar 10, 2011 9:43 am    Post subject: How to assign design parameters for Single Angles?? Reply with quote
Hi all,
Im new to steel design in STAAD. Hence, want to know the design parameters viz kz,ky,Lz n Ly to be assigned for design...plz help.
STAAD orientation for single angles is like inverted V and that indicates the weaker axis i.e. v-v for the angle section is horizontal and major axis here is vertical(u-u).
So shall i rotate the member by using beta angle option or is there any other way of doing the design? Even if i assign 45degree as beta angle, whats next? I mean what parameters should i use as in design of the same?
Any staad model will help....
Thanks n Regards,
Siddhartha
