Dimension tolerance limit for RCC members
saistructure
Gold Sponsor
Gold Sponsor
PostPosted: Sat Nov 05, 2011 4:01 am    Post subject: Dimension tolerance limit for RCC members Reply with quote
Dear friends,  Are there any limit prescribed for dimension tolerance of various members like footing., Column, beams, slabs,etc. in terms of location( their center ), size, plumbness,level,etc. in IS code or other standards?  For example:  # Column center line distance is 2400mm and actual is 2385mm  # size of column is 300mm X 600mm and actual is 290mm X 610 mm  #size of beam is 230mm X 450mm and actual is 200mm X 425 mm  # slab thickness is 125mm actual is 120 mm  # column is out of plumb by 25 mm in one story height of 3000mm  # column is in plumb for bottom 2400mm height and remaining column of 600mm height is out of plumb by 25 mm 3000mm column story height.  # beam sides are out of plumb by 20 mm  # There is difference in slab top level from one corner of building to other corner is 30 mm.  Hiren Desai
Hiren G. Desai Consulting Structural Engineer Govt. Aprroved Valuer 305, Indraprasth Complex, Opp. Subjail, Ringroad, Surat: 395 002 E-mail address: saistructure@rediffmail.com  hirengdesai@hotmail.com Phone: (O) 0261-2357021
Treat yourself at a restaurant, spa, resort and much more with Rediff Deal ho jaye!
PostPosted: Tue Nov 15, 2011 4:49 am    Post subject: Dimension tolerance limit for RCC members Reply with quote
The dimension tolerance can be referred from CPWD specifications Volume -1
Refer para 5.2.2 Design and tolerance in construction
Column and beams section dimensions - - (+)12mm / (-)6 mm
Footing plan dimensions - - - - - - - - (+)50mm / (-)12 mm
Footing thickness - - - - - - - - - - - -(+/-) 0.05 times specified thickness of footing
Eccentricity in plan (footing) - - - - - -
0.02 times the width of footing in direction of deviation but not more than 50mm
Tolerance on placing reinforcement (para 5.3.3.3 of CPWD Spec vol-1)
For effective depth 200mm or less - - - - - - - +10mm
For effective depth more than 200mm - - - - - - - +15mm
Cover deviation - +10mm
Para 5.4.12 may also be seen for payments on measurements with tolerance
best regds
vikramjeet
-- ญญ
