kradhia SEFI Member
Posted: Mon Sep 10, 2012 9:16 am Post subject: RC Chimney |
I am looking for consultant to advise for correction method of RC chimney having serious tilts due to faulty construction method. The tilt/deflection is about 1000+ mm in 150 meter high construction.
The consultation should also include health/stability assessment of present chimney and revised conditions after correction applied chimney. |
ajaymistry SEFI Regulars
Posted: Tue Sep 25, 2012 4:04 pm Post subject: RC Chimney |
kradhia,
This is a very serious problem.Kindly check the tolerances as per ACI-307 or as per older IS 4998.
Recalculate the Second order Moments at each & every levels and P-Delta effect as given in CICIND.
Is it a Brick-Flue chimney or Steel Flue Chimney?
Try to check reinforcement & section based on second order moments by using Limit state Method (esp. at openings).
Ajay VM |
