ductile detailing
vjkpatil at bom2.vsnl....
PostPosted: Tue Oct 14, 2003 11:48 am    Post subject: ductile detailing Reply with quote
----- Original Message -----
To: e-conf@sefindia.org
Sent: Tuesday, October 14, 2003 8:22 AM
Subject: ductile detailing
I agree with Mr. Vipul. If ductile detailing is to be carried out for
earthquake what code do we refer. In concrete structures the steel
reinforcement is increased by certain proportion to achieve ductility. What
measures are to be taken for steel structures esp. the connections.
What are the measures to be taken in case of composite construction where
there may be different cases of only columns are composite and the beams are
not or vice versa.
Coming to Design of composite structures it is not mentioned at all except
in the appendix that to for vibration of floors. But in India composite
steel deck floor are still not used because the codes are not available.
Niether the clients nor the manufacturers want to spend on experimental
design. In India the steel structure can be economical if it is used as a
composite structure. One of the INSDAG's publications for design of
composite floors (deck span) clearly says that the design example is based
on BS 5950 as no mention of it is found in IS :800 now that the code is
being revised it is necessary to incorporate composite section designs.
Vijay Patil
