Proposed REVISION OF IS:456-2000- Inviting Comments
Goto page 1, 2, 3 ... 15, 16, 17  Next
PostPosted: Tue Jan 08, 2013 4:00 pm    Post subject: Proposed REVISION OF IS:456-2000- Inviting Comments Reply with quote
I came to know from Mr Sanjay Pant, Director (Civil Engineering)
Bureau of Indian Standards, that they are going to take up the revision of IS 456 soon. Hence our Er Mallick proposed the idea of collecting comments from our SEFIans, which can be passed on to BIS. Hence I am starting this Tread. Please post your comments only in this tread and not in several other places.
Best wishes,
Thankful People
francis chacko
PostPosted: Tue Jan 08, 2013 4:15 pm    Post subject: Proposed REVISION OF IS:456-2000- Inviting Comments Reply with quote
hemal
PostPosted: Wed Jan 09, 2013 5:52 am    Post subject: Proposed REVISION OF IS:456-2000- Inviting Comments Reply with quote
Dear Sefi Members,
I hope future revision of IS:456 will include section property modifiers (i.e. for I, A etc) for various structural elements (i.e. column, shear wall, link beam, beam, slab etc of RC & PT) to account for cracking for basic guidelines.
Hemal Mistry
Surat
On Tue, 8/1/13, Dr. N. Subramanian <forum@sefindia.org> wrote:
Subject: [SEFI] Proposed REVISION OF IS:456-2000- Inviting Comments
To: general@sefindia.org
Date: Tuesday, 8 January, 2013, 10:00 AM
Best wishes,
Manoharbs_eq
PostPosted: Wed Jan 09, 2013 6:09 am    Post subject: Reply with quote
Really glad to hear that 456 is getting revised
my view in updating 456 would be
1) Inclusion of P-delta parameters and column length factor
2) Inclusion of flat plates
3)Design procedure for Box RCC structures
4) Min reinforcement for Rc wall and shear wall be separated.
Rgds
Manohar
abhio
PostPosted: Wed Jan 09, 2013 11:33 am    Post subject: Reply with quote
My USD 0.02:
  1. Improve recommendations for design of corbels and deep beams - see ACI 318 to know the difference!
  2. Provide a section on strut-and-tie modelling.
  3. Unify RCC and prestressed concrete codes.
  4. Provide recommendations, stress block etc. for ultra-high strength concretes.
  5. Provide crack width calculation method for elements under combined axial tension and bending.
  6. Provide recommendations for pozzolanic cement based concretes, high volume fly ash replacement of cement.
  7. Provide a section on anchoring to concrete - see ACI 355/ ACI 318.
brahmabul
PostPosted: Wed Jan 09, 2013 12:17 pm    Post subject: Reply with quote
First of all many thanks to Dr NS sir for starting this topic. It is really high time that IS 456 gets revised now.
I would like to have following inclusions in the updated code:
1. Inclusion of Fe 550 and Fe 600. IS 1786 has already given the chemistry for Fe 550 and Fe 600 rebar but unless IS 456 allows its use in structural designing, it will be of no use. In SP 16 there is no design stress-strain curve for Fe 500 and Fe 600 [Ref: Fig 3 of SP 16]
Major steel producers like Tata Steel have already developed 600 grade with sufficient amount of ductility and UTS/YS ratio. It can be commercialized on a large scale only if the inclusion is made in IS 456.
2. Increasing the limit on characteristic strength of stirrup to 500 MPa. It is right now limited at 415 MPa [Ref: Cl.26.5.1.6]
sunilgurtoo
PostPosted: Wed Jan 09, 2013 12:40 pm    Post subject: Proposed REVISION OF IS:456-2000- Inviting Comments Reply with quote
Dear SEFI members,
For the Flat Plat Construction, IS codes should include the use of STUD Rails /Punching Shear Reinforcement which is mostly used as per US codes In us and other parts of the world.
I have seen lot of stuff from internet for the stud rail and punching shear reinforcement technology, but IS codes being the main governing guidelines, it should include the same.
Sunil Gurtoo
pune
Sent: 09 January 2013 17:47
Subject: [SEFI] Re: Proposed REVISION OF IS:456-2000- Inviting Comments
Dear Sefi Members,
Hemal Mistry
Surat
On Tue, 8/1/13, Dr. N. Subramanian wrote:
--auto removed--
 Filesize:  823 Bytes
 Viewed:  2088 Time(s)
sunny
PostPosted: Wed Jan 09, 2013 3:05 pm    Post subject: Proposed REVISION OF IS:456-2000- Inviting Comments Reply with quote
Dear subramanian sir,
I just want to ask that,last month we had very effective session on Tall Buildings.
Is there any conclusion/summary sheet with us?
If yes than can you provide that to all sefians??
Kunal Talsania
Structural Design Engineer On Jan 9, 2013 5:49 PM, "hemal" <forum@sefindia.org (forum@sefindia.org)> wrote:[quote]            Dear Sefi Members,
Hemal Mistry
Surat
      --auto removed--
PostPosted: Wed Jan 09, 2013 3:39 pm    Post subject: Reply with quote
when giving comments, is it not better to include IS 456 Clause, so that it is easy for those at BIS?
Dear Er Manohar,
1) Inclusion of P-delta parameters and column length factor- What do you mean by Column length factor?
2) Inclusion of flat plates- Flat plates are there in Clause 31.
3)Design procedure for Box RCC structures - Since Box sections are often used in bridges, I am not sure whether provisions will be added. But it will be good if they consider including it.
Best wishes,
1. Inclusion of Fe 600. IS 1786 has already given the chemistry for Fe 600 rebar but unless IS 456 allows its use in structural designing, it will be of no use. In SP 16 there is no design stress-strain curve for Fe 600.
2. Increasing the limit on steel grade for stirrups to 500 MPa. It is right now limited at 415 MPa.
PostPosted: Wed Jan 09, 2013 4:40 pm    Post subject: Re: Proposed REVISION OF IS:456-2000- Inviting Comments Reply with quote
Dear Er Hemal,
I have asked Er Sanjeev about it. He will reply soon.
Best wishes,
[quote="sunny"]Dear subramanian sir,
Kunal Talsania
Structural Design Engineer On Jan 9, 2013 5:49 PM, "hemal" <forum> wrote:
             Dear Sefi Members,
Hemal Mistry
Surat
      --auto removed--
Page 1 of 17
