rajmane ...
Posted: Fri Nov 17, 2006 12:02 pm Post subject: No Title |
17-11-2006
Dear all
(1) I tend to agree with Shri Daljeet that M20 is possible with : 1:1.5:3, hand mixing, water cement ratio of 0.525 (= 5% of aggregates + 30% of cement ), and 33 grade OPC cement. However, let us also consider the following aspects.
(2) Unless we have mentioned w/c ratio, we can not say that we have defined any concrete adequately. Again I say that unless all the three parameters of concrete (w/c ratio, cement content, concrete strength) as given in IS : 456-2000, are explicitly mentioned, concrete can not be taken to be suitable for structural use as per IS:456-2000.
(3) We must also remember that a given proportions can give a very wide range of concrete strengths depending upon the cement strength (cement grade can not define the actual cement strength).
Thanking you all, with regards
N P Rajamane Deputy Director and Head, Concrete Composites Lab, Structural Engg Research Centre, CSIR, Taramani, Chennai 600113 (Ph : 22549152 (D), 22549150 (CCLab), Res: 224417882) Email : rajmane[AT]ser..., rajamanenp[AT]yah...
PS : The above opinion is personal and it may not be necessarily the view of SERC.
sidhudaljeet[AT]yah... wrote:
Quote: | Dear N P Rajamane 1:1.5:3 for M-20 was used for hand mixed non vibrator concretes with water cement ratio based on water (5% of aggregates + 30% of cement ) Thus water cement ratio of 0.525. I think even today if you use hand mixed concrete and donut use vibrator 33 grade OPC cement and water cement ratio 0.525, M-20 would be a great achievement. Daljeet rajmane[AT]ser... wrote:
13 Nov 2004
Dear all
(1) I do not agree that nominal mixes are " The Nominal Mix for M20 concrete is 1:1.5:3, for M15 is 1:2:4". For RCC, we have to think of durability which is ensured by suitable adoption of w/c ratio. In the absence of inclusion of w/c ratio in defining the concrete mix or grade, the concretes can not be taken as acceptable. Defining/describing the concrete without w/c ratio should stop in the interest of the concrete constructions, especially, when the cement is produced in modern cement plants where high strength cements are easily and consistently produced and made available to engineers without much effect on final price.
(2) I am very glad about the following observation by Shri Basu, Pranab:
"Design Mix is a design of concrete mix where all the actual design requirements as per the actual materials and working conditions are taken care of. The main design considerations are Structural Strength, Standard Deviation in strength, Durability of structure (minimum cement content), physical and chemical properties of building materials, exposure of the structure, workability factor and above al the available resources for commercial viability."
However, I wish to add that the words "Durability of structure (minimum cement content)" should be replaced with "Durability of structure (minimum cement content, max. w/c ratio, minimum grade, for a particular exposure condition)".
(3) Let us accept important observations of Prof. Kalgal. A given mix proportion can give a wide range strengths, say ranging even from as less as 10 MPa to as high as 100 MPa depending upon several factors such as type and strength of cement strength, w/c ratio, presence/absence of mineral and chemical admixtures, type of mixer machine, transportation, placing and curing operations, age, etc.
Yours sincerely
Akshaya.Das[AT]ake... wrote:
Quote: | Dear Sefian,
Here is some comment from a very experienced engineer in the construction field. I thought to share this with you all.
Dr A K Das
________________________________
Message From Basu, Pranab Sent: Friday, November 10, 2006 4:53 PM To: Das, Akshaya Subject: nominal mix design
I could not understand as to where from the discussion evolved? Unless you know the purpose, you might not contribute significantly. However like others, I can share my knowledge in the following manner.
1. First of all there is no terminology like Nominal Mix Design. Nominal Mix is a recommendation by IS 456 based on statistical data from several regions. Obviously the structural strength as well s the durability factor remained in consideration.
The Nominal Mix for M20concrete is 1:1.5:3, for M15 is 1:2:4
2. Design Mix is a design of concrete mix where all the actual design requirements as per the actual materials and working conditions are taken care of. The main design considerations are Structural Strength, Standard Deviation in strength, Durability of structure (minimum cement content), physical and chemical properties of building materials, exposure of the structure, workability factor and above al the available resources for commercial viability.
Design Mix is always an economic option but require technical competence.
I do not know how my vies can help one, if the problem or the issue is not known.
-----Original Message----- Message From Das, Akshaya Sent: Friday, November 10, 2006 4:31 PM To: Basu, Pranab Subject: FW: nominal mix design
Interesting discusiion!!!!!
Akshay
Message From rajmane[AT]ser... [mailto:rajmane[AT]ser...]
Sent: Friday, November 10, 2006 10:00 PM
To: Das, Akshaya
10 Nov 2004
Dear all
I do not agree that nominal mix design of reinforced concrete M20 it is 1:2:3. For RCC. We have to always note that a design mix which should satisfy both strength (used in design of structures) and durability requirements (max. w/c ratio, minimum cement content, minimum grade, for a particular exposure condition) as per IS:456-2000. When we say RCC, I feel, we mean only structural concrete. Then durability requirements of Codes have to be ensured.
dipeshtanuja[AT]red... wrote:
Quote: | Regarding nominal mix design of reinfirced concrete M20 it is 1:2:3 of
| cement:sand:ageeregate with watercement ratio.
Quote: | On Thu, 09 Nov 2006 parikshit_pandya[AT]red... wrote :
Quote: | Quote: | what are the general thumb rules for nominal mix design?
Quote: | Quote: | email to ========powered by Reach1to1
Everywhere
This e-mail and any attachment are confidential and may be privileged or otherwise protected from disclosure. It is solely intended for the person(s) named above. If you are not the intended recipient, any reading, use, disclosure, copying or distribution of all or parts of this e-mail or associated attachments is strictly prohibited. If you are not an intended recipient, please notify the sender immediately by replying to this message or by telephone and delete this email and any attachments permanently from your system.
Find out what India is talking about on - Yahoo! Answers India Send FREE SMS to your friend's mobile from Yahoo! Messenger Version 8. Get it NOW
Guest Guest
Posted: Mon Apr 28, 2008 12:38 am Post subject: No Title |
3.Constitution of Council of Architecture.- (1) The Central Government shall, by notification in the Official Gazette, constitute, with effect from such date as may be specified in the notification, a Council to be known as the Council of Architecture, which shall be a body corporate, having perpetual succession and a common seal, with power to acquire, hold and dispose of property, both movable and immovable, and to contract, and may by that name sue or be sued.
(2) The Head Officer of the Council shall be at Delhi or at such other place as the Central Government may, by notification in the Official Gazette, specify.
(3) The Council shall consist of the following members, namely :-
(a) five architects possessing recognised qualifications elected by the Indian Institute of Architects from among its members :
(b) two persons nominated by the All India Council for Technical Education established by the Resolution of the Government of India in the late Ministry of Education No.F.16-10/44-E.III, dated the 30th November, 1945;
(c) five person selected from among themselves by heads of architectural institutions in India imparting full-time instruction for recognised qualifications;
(d) the Chief Architects in the Ministries of the Central Government to which the Government business relating to defence and railways has been allotted and the head of the Architectural Organisation in the Central Public Works Department, ex officio;
(e) one person nominated by the Central Government;
(f) an architect from each State nominated by the Government of that State;
(g) two person nominated by the Institution of Engineers (India) from among its members; and
(h) one person nominated by the Institution of Surveyors of India from among its members.
Explanation.-For the purposes of this sub-section,-
(a) " Institution of Engineers (India)" means the Institution of Engineers (India first registered in 1920 under the India Companies Act, 1913 (7 of 1913) and subsequently incorporated by a Royal Charter in 1935.
(b) "Institution of Surveyors of India" means the Institution of Surveyors registered under the Societies Registration Act, 1860 (21 of 1860).
(4) Notwithstanding anything contained in clause (a) of sub-section (3), the Central Government may, pending the preparation of the register, nominate to the first Council, in consultation with the Indian Institution of Architects, persons referred to in the said clause (a) who are qualified for registration under section 25, and the persons so nominated shall hold officer for such period as the Central Government may, by notification in the Official Gazette, specify.
(5) Notwithstanding anything contained in clause (f) of sub-section (3), the Central Government may, pending the preparation of the register, nominate to the first Council, in consultation with the State Governments concerned, persons referred to in the said clause (f), who are qualified for registration under section 25, and the person so nominated shall hold officer for such period as the Central Government may, by notification in the Official Gazette, specify.
now.
around
around
around
Yahoo! Photos – Showcase holiday pictures in hardcover Photo Books. You design it and we’ll bind it!
Guest Guest
Posted: Mon Apr 28, 2008 12:40 am Post subject: No Title |
What could be the reason of water as well as wet sand is percolating out of the building boundaries from all sides? Is it a serious warning for a disaster?
Guest Guest
What are the most popular cars? Find out at Yahoo! Autos
Guest Guest
Jiyo cricket on Yahoo! India cricket
Guest Guest
Posted: Mon Apr 28, 2008 12:53 am Post subject: No Title |
I had the swirl and ache
Guest Guest
I craved strong sweets, but those Seemed strong when I was young; The petal of the rose It was that stung.
Now no joy but lacks salt That is not dashed with pain And weariness and fault; I crave the stain
Of tears, the aftermark Of almost too much love, The sweet of bitter bark And burning clove.
When stiff and sore and scarred I take away my hand
Guest Guest
The hurt is not enough: I long for weight and strength To feel the earth as rough To all my length.
Guest Guest
Posted: Mon Apr 28, 2008 1:03 am Post subject: No Title |
whereas in stuctures designed based on Limit state the load factors are clearly spelt out as 1.2 and 1.5 respectively.
Thus for Truss members where DL+WLcasegoverns, an increase of stresses are taken evn though WL(=100-120) >> DL(=25 to 30Kg/cm2). This can be seen in SP-38 at clause 2.2
However for Tower structures, one can say that wind load is main load vis-a vis DL. and no increase.
with regards
vikramjeet
Guest Guest
Posted: Mon Apr 28, 2008 1:35 am Post subject: No Title |
