mashetty.rahul SEFI Member
Posted: Thu Oct 03, 2013 9:12 am Post subject: GRADE OF CONCRETE |
Sir/Madam,
My qustn seems to be silly.but i would lyk to clarify my doubt.,y dont we use 2 diff grades of concrete at a time???
for example..i would lyk to cast a RCC beam.so i ll use higher grade of concrete in places where there is more B.M an lesser grade where der is less B.M.. is dat possb??
if not ..wat are the factors that effects this criteria.. |
mahantesh_83 SEFI Member
Joined: 20 Dec 2011 Posts: 11 Location: Mumbai, India
Posted: Thu Oct 03, 2013 2:17 pm Post subject: Grade of Concrete |
Dear Rahul,
Different grades of concrete can be used at a time, but it will increase the efforts of designer as well as it needs very careful supervision while concreting.
Designer needs to put more efforts in assessing the maximum moments at different locations & their range. They have to mention different grades at different locations on drawing as well. This will increase the man-hours.
While concreting, it needs very careful supervision. If by mistake lower grade of concrete is poured at the locations where you need to put higher grade, it is difficult to remove at beam locations.
This can lead to increase in project cost, instead of decreasing.
In my opinion it is not advisable to use different grades.
Mahantesh Nagannavar |
Posted: Fri Oct 04, 2013 6:02 am Post subject: |
what all things that effect??
bond strength???
transfer of loads?? |
