P Large Delta using storey magnifier method as per IS 800-20
Rameshwar Prasad
PostPosted: Tue Nov 05, 2013 6:26 am    Post subject: P Large Delta using storey magnifier method as per IS 800-20 Reply with quote
Hi All,
If i were to take into account P-Large delta using storey magnifier method  the formula mentioned on pg 276 in design of steel structures by Dr. N Subramanian gives the value of the "maximum end moment"
based on maximum first order end moment for a storey.
1. My main point of contention is whether all the columns in a particular storey are to be of the same size to apply this formula.
2. Are all the columns in a single storey to be designed for the same approximated "maximum second order end moment"?
PostPosted: Wed Nov 06, 2013 4:33 am    Post subject: Re: P Large Delta using storey magnifier method as per IS 80 Reply with quote
Dear Er Prasad,
I do not have the paper by Chen and Lui(1985) with me now.Chen, W.F, and Lui,   E.M., Stability design criteria for steel members and frames in the United   States, Journal of Constructional Steel Research, Vol. 5, 1985, pp.   31-74, Discussion by Vandepitte, Vol. 6, No. 1, 1986, pp. 76-79.
However, to answer to your question (1): it is not necessary that all the columns in a particular storey are to be of the same size to apply this formula.
For question (2) You will have the first order end moment from the linear analysis computer program for different columns. You need to multiply those values by the moment amplification factor in order to get the moment including P-Delta effect.
Rameshwar Prasad wrote:
Hi All,
Rameshwar Prasad
PostPosted: Wed Nov 06, 2013 12:54 pm    Post subject: Doubt Solved!! Yet another raised... Reply with quote
Hi Dr. N
You know its kind of a privilege when the person, whose book you are referring solves your query. Thank You. If you dont mind i posted another doubt on the forum regarding P-small delta approximation for a beam column. i am pasting the URL of the link. Can you please sort that out too?
http://www.sefindia.org/forum/viewtopic.php?t=15233
Rameshwar Prasad
PS You are a source of inspiration for many. Keep Inspiring!!!
