:Connections
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> Past Discussions Year 2006
nrupeny
PostPosted: Mon Nov 13, 2006 12:32 pm    Post subject: :Connections Reply with quote
Hi Friends,
Please can anyone let me know,
- What are Prying forces in connections.
- Where it significane will be considered.
REGARDS
NRUPEN.R.Y
!-- Virus-Free Mail Using PostMaster Express AvAc & QuickHeal Engine --!
Design Excellence (India) Pvt Ltd, Thane, India
loveablejigar
PostPosted: Mon Nov 13, 2006 12:48 pm    Post subject: :Connections Reply with quote
Hello,
Prying forces are generally considered in a hanger type connection. In this connection due to the pull the bending of plate or an angle occures due to which the force is generated at the outer edge of the connection element and that is called as prying force.
Jigar Shah
Design Engineer,
Hidada Ltd
nrupeny[AT]des... wrote: Hi Friends,
REGARDS
NRUPEN.R.Y
Everyone is raving about the all-new Yahoo! Mail beta.
Amol.Taralkar
PostPosted: Wed Nov 22, 2006 9:59 am    Post subject: :Connections Reply with quote
HI Nrupen,
When the connecting member is not very stiff and undregoes deformation
at connection then the force generated at contact surface of the
outstanding part of connecting member beyond bolt is prying force.
Let, Tee is connected to plate with two bolts at each side of web of
Tee. If the flange of tee is relatively flexible, it bends under applied
load and the flanges outside the bolts are pressed against the
supporting plate. The reactions generated at the points of contacts are
Prying forces.
Prying forces are significant when connecting member is not very stiff
and can undergo deformation.Also when connected part spans between two
or more supporting parts.
For more information you just refer:
STEEL DESIGNERS' MANUAL
THE STEEL CONSTRUCTION INSTITUTE
EDITED BY: Buick Davison
Graham W. Owens
regards,
Amol H. Taralkar
Aker Kvaerner Powergas Pvt. Ltd.
+91 22 6706 6365
+91 9833829959
-----Original Message-----
Message From  nrupeny[AT]des... [mailto:nrupeny[AT]des...]
Sent: Monday, November 13, 2006 11:32 PM
To: Taralkar, Amol
Subject: :Connections
Hi Friends,
REGARDS
NRUPEN.R.Y
Everywhere
This e-mail and any attachment are confidential and may be privileged or otherwise protected from disclosure. It is solely intended for the person(s) named above. If you are not the intended recipient, any reading, use, disclosure, copying or distribution of all or parts of this e-mail or associated attachments is strictly prohibited. If you are not an intended recipient, please notify the sender immediately by replying to this message or by telephone and delete this email and any attachments permanently from your system.
nrupeny
PostPosted: Wed Nov 22, 2006 11:20 am    Post subject: :Connections Reply with quote
Thanx a lot Mr Amol.
REGARDS
NRUPEN.R.Y (Design Engineer)
DESIGN EXCELLENCE (INDIA) Pvt.Ltd
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> Past Discussions Year 2006 All times are GMT
