bysaniam SEFI Member
Posted: Mon Dec 04, 2006 10:02 am Post subject: raft-foundation |
Blankdear sefians , does any one can help in designing the raft-foundation for 4 legs of tower were one leg is critical in uplift and the other is leg in compression. were most of the books referred to only compression , does any one have designed a raft to take care of uplift as well as compression. any material on this his highly appreciated.(excel ,sheets) B.Aravind Kumar PGET KEC-International Ltd Mumbai 9890092094
This e-mail was scanned for viruses using BitDefender Sent by 602LAN SUITE - http://www.software602.com/
gsrinivasbabu SEFI Member
Posted: Mon Dec 04, 2006 2:08 pm Post subject: raft-foundation |
Design of raft for a tower can be done as usual normal raft foundation,But is to be checked for Ceck for 1) Over turning 2)Down thrust 3)Punching shear Check against overturning plays key role in the design of raft foundation for a tower. Tocheck for OT First calculate the overturning moment whch can be obtained by multiplying the base width of the tower with twice the down thrust. Then calculate the Stabilizing moment Stabilizing moment= W*B/2 Where w=weight of soil above raft+weght of concrete including self weight of raft B= base width of foundation FOS =Stabizing moment 7 Overturning moment and must be greaster then 1.5 Checking don thrust can be done by calculating P/A*M/Z of the raft and this value must be less then SBC depth of pad can be calculated from Punching shear calculations as usal. Generally we get minimum steel in in pad in both the direction at top and bottom. Columns can be designed with help of SP16 charts as biaxial members(Tension+ bending) I think it is sufficient for you. Any clarifications pls dont hesitatae to ask me G.Srinivas Babu Senior designer Towers wing SVPCPL Hyderabad
On Mon Dec 4 15:32:52 2006, bysaniam[AT]kec... <bysaniam[AT]kec...> wrote:
Quote: | Blankdear sefians , does any one can help in designing the raft-foundation for 4 legs of tower were one leg is critical in uplift and the other is leg in compression. were most of the books referred to only compression , does any one have designed a raft to take care of uplift as well as compression. any material on this his highly appreciated.(excel ,sheets) B.Aravind Kumar PGET KEC-International Ltd Mumbai 9890092094
