perwez at lntecc.com Guest
Posted: Wed Dec 06, 2006 10:04 am Post subject: Message from perwez |
Dear Mr. Sukanta Please see an excerpt from an article of Dr. SK Jain in ICJ - November 2003.
In Clause 7.8.2.1, the code specifies damping to be used for steel buildings as 2 percent of critical, and for RC buildings as 5 percent of critical. This leads to a steel building being designed for about 40 percent higher seismic force than a similar RC building. While it is true that in a RC building the damping may be higher due to development of micro cracks in concrete; however, steel buildings have inherent advantages of better seismic performance. Moreover, both an RC building and a steel building may have the same types of partitions and other non-structural elements which will contribute same material damping. Hence, it cannot be justified that steel buildings should be designed for 40 percent higher design forces than similar RC buildings. Clearly, specification of damping has a direct bearing on the seismic design force level and considering this, it is recommended that the code should require both steel and RC buildings to be designed for 5 percent damping.
Kind Regards Perwez Ahmad ========================== Perwez Ahmad Senior Design Engineer L&T ECC Division Mount Poonamallee Road Manapakkam, PB No. 979 Chennai-89 Mobile: +91-9840619804 Office: +91-44-22528486 perwez[AT]gma... ahmad_perwez[AT]yah... ===========================
-----Original Message----- Message From sukanta.adhikari[AT]gma... [mailto:sukanta.adhikari[AT]gma...] Sent: Wednesday, December 06, 2006 8:49 PM To: Perwez Ahmad Subject: seismic
Dear sefians,
I want to know why does a steel structure experiences 40% more seismic forces compared to R.C.C structure.
Regards, S.Adhikari
DISCLAIMER: This Message and its contents is intended solely for the addressee and is proprietary.Information in this mail is for L&T Business Usage only. Any Use to other than the addressee is misuse and infringement to Proprietorship of L&T ECC.If you are not the addressee please return the mail to the sender.L&T ECC DIVISION
