Crane Load Distribution on Grade Slab
karthick_ce
PostPosted: Mon Jun 30, 2014 3:46 am    Post subject: Crane Load Distribution on Grade Slab Reply with quote
I'm having a doubt about the load application of the crane outrigger post on the grade slab. is the load pressure on the slab to be calculated based on the dispersion or based on the bearing area? i modelled a concrete grade slab in Staad as plate element and i applied the load as pressure on the slab based on the dispersion of load from top to bottom of slab. is my approach is correct?
load application approach.docx
 Filename:  load application approach.docx
 Filesize:  27.55 KB
 Downloaded:  286 Time(s)
