Joined: 21 Feb 2008 Posts: 5496 Location: Gaithersburg, MD, U.S.A.
Posted: Thu Aug 14, 2014 9:30 pm Post subject: |
Dear Er Atif,
The cantilever is simple and the BM can be calculated at the end as wL^2/2 and this can be given as the moment at the fixed end. The beam is resting only on the interior beam!
mohd atif wrote: | thanks everyone for replying,
please check staad file , skecth
file name staad corresponds to the sketch
and file name staad 2 beam 339 contains long cant beam with similar problem
the long cant beam is about 15 feet length |
mohd atif SEFI Member
Posted: Fri Aug 15, 2014 1:24 pm Post subject: |
respected sir ,
but the reactions through the continuous unsupported beam will act on the long beam or
the long beam will act as a propped cantilever with the stiff cantilever supporting the unsupported beam
please rectify my doubt |
Posted: Fri Aug 15, 2014 2:03 pm Post subject: |
Dear Er atif,
My God! Only now I looked into the sketch sent by you properly. You have a very long beam which is supported only on cantilever beams, on which many other heavy beams also are supported. I will not approve such a beam. Please provide columns, especially where a long beam is supported by it. Otherwise, the behavior of the system will not be proper.
mohd atif wrote: | respected sir ,
Posted: Sat Aug 16, 2014 2:22 pm Post subject: |
respected sir,
thank you for reply . there are some restriction (parking and dining) because of that i cannot place a column to support the other end of long beam.
how should is consider the long beam
1. cantilever, where the continuous unsupported beam reaction will be transferred to each cantilever beam and the long beam will be having high moments at the end
or
2. propped cantilever , where the stiff cantilever beams are supporting continuous unsupported beam and the long beam resting on this continuous unsupported beam
sir which one is proper way to analyse |
Posted: Sat Aug 16, 2014 5:20 pm Post subject: |
Dear Er Atif,
The column locations as shown in your drawing will not constitute a proper system.
You should move the columns to support the beams, so that the system will have clear load path.
mohd atif wrote: | respected sir,
or
Posted: Sat Aug 16, 2014 7:49 pm Post subject: |
respected sir ,
i am not able to move the column because of stipulation set by architect and owner ( due to parking and hall) .
sir , can't we analyse the structure without moving column position
i could change the beam position
and thank you for reply
sir cant we release moment from each secondary beam as shown below in the image
is it the right way or stiff cantilever supports unsupported beam and less stiffer cantilever rest on it
please rectify me |
