BATTEN PLATE SPACING
pravin_shirsath
PostPosted: Wed Dec 17, 2014 8:33 am    Post subject: BATTEN PLATE SPACING Reply with quote
I have to give batten plate spacing for channel placed back to back.
channels are braced & without braced effective length changes.
as per IS 800 clause 7.7.3
spacing  = 0.7times slendeness ratio of member.
for braced column slenderness ratio is less compared to unbrace column.
so spacing required for braced column is less compare to unbraced column.
Can you please see attached file?
please comment.
 Filesize:  29.55 KB
 Viewed:  709 Time(s)
abhy_vivek
PostPosted: Thu Dec 18, 2014 9:17 am    Post subject: Re: BATTEN PLATE SPACING Reply with quote
Pravin I think there is some confused made amongst - words Lacing / Bracing and battening ?
what is your exact question is also not clear, so no one has yet replied to your query.
please comment.
pravin_shirsath
PostPosted: Thu Dec 18, 2014 9:59 am    Post subject: Reply with quote
column back to back channel sections are same for Frame 1 & Frame 2
1) Frame 1 :
colums are placed back to back channels (open section) and columns are braced by tube for framing(connected at web).
my question is if i have to give batten at flanges,
Effective length is less than frame 2 due to bracing.
hence  for braced frame,spacing requirement is less due to slenderness ratio & due to IS 800 clause.
2) Frame 2 :
Effective length is more compare to frame 1.
hence  unbraced frame (without tube) slenderness ratio is more , so spacing required is more.
I am little confused with Clause for braced column (frame 1) ,batten spacing requiement is less compare to unbrace column (frame 2)?
PostPosted: Fri Dec 19, 2014 2:46 am    Post subject: Reply with quote
Dear Er Pravin,
First of all the column shown by you is a laced column and not a battened column.
You must check local as well as overall buckling. For laced column the length to be taken is 1.05L.
The system shown by you is not efficient. You need to keep rxx and ryy more or less same. Moreover welding of the tube in between the channels may give practical difficulties.
pravin_shirsath
PostPosted: Sat Dec 20, 2014 9:10 am    Post subject: Reply with quote
Thank you NS sir for your reply.
I am planning bolting between column web & tube.
as my setion is open i.e. back to back channel with inside lacing ,
what i understand is i do not  need batten plate for laced column.
but flanges are open & these sections are cold formed ??
is there any example or any references for such type of cases??
Pravin K Shirsath
abhy_vivek
PostPosted: Mon Dec 22, 2014 8:06 am    Post subject: Reply with quote
Pravin, if you do not mid one quick question.
Has your boss or any experienced senior checked this structural configuration, before you post it on Sefi ?
I again, repeat, that this question is not to discourage you or any Young Growing Structural Engineer from asking questions in forum. But just wanted to find out 'Whether the designers / Structural Engineers in India or elsewhere' are learning on their own, by trail and error ?. . . If so then the trend is not good for 'Structures Health'.
Reg
Vivek
Pravin K Shirsath
pravin_shirsath
PostPosted: Tue Dec 23, 2014 8:19 am    Post subject: Reply with quote
I really concern with your worry about structrual safety. this is some research type of work.
Very good research scientist & structural engineer having age more than 60 years is involved in this type of work.
I am just collecting information for my reference.
abhy_vivek
PostPosted: Wed Dec 24, 2014 12:06 pm    Post subject: Reply with quote
Ok Pravin,
   Good to note that you have mentors who are highly experienced (at least in terms of age).
   In past couple of months, I came across not less than 10 / 12 designers who are working in
isolation without any guidance / mentor in India, China, Dubai, S. Korea etc. They are struggling
for guidance / literature. Some times refer wrong / superseded references. And somehow complete
the designs.
   Industry should do something to face such reality. Otherwise the structures will be in danger.
There are many Big Consulting companies who outsources the work to small companies / individuals
Finally the work suffers.
Reg
Vivek
dipak_bhattacharya
PostPosted: Sun Jan 04, 2015 4:39 pm    Post subject: Batten Plate Spacing Reply with quote
This is today's scenario in Indian Private Consulting Companies.
Culture is not to spend any money or waste time on any employee engineer. They recruit fresh / inexperienced  engineers with  pitiable salaries,because supply of engineers passing from private colleges are much more than the requirement of the market.In critical situations only, those private company owners outsource the assignments.
The other side of the story is that those junior engineers always remain on the lookout of jumping from one company to other and quit at the earliest opportunity, only for better money.They can't be retained by any means because the employer has trained them.
So who is to blame whom?And who can help the situation? Companies are struggling to survive.
Experienced engineers are busy and do not find it worthy to waste time on this kind of forums.
