ben solomon SEFI Member
Posted: Sun Oct 23, 2016 5:59 am Post subject: Effective Length in STADD |
How to verify the effective length of the column after analysis for a steel member?
If a cantilever beam having effective length 2L how can i validate the result of the member that it takes the effective length for analysis?
Thanks in advance. |
saikiran gone General Sponsor
Posted: Mon Oct 24, 2016 12:31 pm Post subject: Re: Effective Length in STADD |
ben solomon wrote: | How to verify the effective length of the column after analysis for a steel member?
Hi Ben solomon,
You can give design parameter in staad KY,KZ as 2 and same result can be check in STAAD Output. |
Posted: Mon Oct 24, 2016 12:55 pm Post subject: Re: Effective Length in STADD |
Dear saikiran gone,
Thank you for your response.
one more question...,
If a member having a node in between that splits the member into two (R1,R2)and i want to determine the overall effective length of the member.
is it possible to get output for the effective length of the member as a single unit.
if it so
explain me briefly
otherwise
give me the alternative.
Benil.R |
Posted: Tue Oct 25, 2016 12:51 pm Post subject: Re: Effective Length in STADD |
Yes off course , try to assign LZ & LY for example :
Your member divides as 0.5+0.7m assign the design parameters LZ & LY as 1.2 m if no restraint (like Purlins ) present in both the directions and the result in output.
With best,
Saikiran.
ben solomon wrote: | Dear saikiran gone,
if it so
explain me briefly
otherwise
Benil.R |
Posted: Tue Oct 25, 2016 1:08 pm Post subject: |
Thanks for your kind explanation. |
