Felix.Antony SEFI Member
Posted: Fri Mar 31, 2017 1:34 am Post subject: Metal Deck and Foam Concrete |
Recently, I came across with a idea of Metal deck RCC slab to reduce the weight of the roof since the roof is to be laid on the existing steel shed.
However, when I made some research, there was the item called Faom Concrete which is being used over Metal Deck to reduce the weight.
Can somebody through light on this Foam Concrete and proper application of metal deck RCC slab |
