Backstay diaphragm with level difference (offset)
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies. Thank Post    www.sefindia.org Forum Index -> E-conference on IS 16700 13th March to 18th March 2018
hemalmistry
PostPosted: Mon Mar 19, 2018 6:13 pm    Post subject: Backstay diaphragm with level difference (offset) Reply with quote
Generally, tower slab and podium slab are not at same level. Say, i have a level difference of 600 mm between tower slab and podium slab. 750 deep periferel beam of tower is supporting podium slab at beam bottom and tower slab from beam top.
Such backstay diaphram with level difference will be effective as alternative path  to transfer lateral load to supporting element?
Like restriction in size and location of opening in backstay diaphragm, is there any restriction regarding maximum permissible level difference in backstay diaphragm?
Modeling and design of beam supporting podium slab from bottom and tower slab from top may be crucial.
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies. Thank Post    www.sefindia.org Forum Index -> E-conference on IS 16700 13th March to 18th March 2018 All times are GMT
