Is steel rebar resiliant in case of fire
rekhar
PostPosted: Sat Dec 15, 2018 7:01 am    Post subject: Is steel rebar resiliant in case of fire Reply with quote
Is Steel rebar resilient enough to be called safe in case of a fire
Aneesh_Surjith
PostPosted: Sat Dec 29, 2018 6:21 am    Post subject: Steel rebars have evolved to withstand fire but i not unaffected by fire Reply with quote
There is no true resilient steel to fire, as fire is an uncontrolled phenomenon whose temperature can sore up. Fire is one of the worst disasters that can cause damage to structures. Like any other material. steel also has a weak point which is when the temperature of structural steel rises around 425C, it begins to soften and by the time it reaches about 650C, half the strength is lost. This condition eventually leads to structural integrity failure. But by using TMT steel reinforced bars, it can withstand higher temperatures than normal steel bars and maintain the structural integrity.
