The collapse of footbridge at mumbai.
sktrisal
PostPosted: Wed Mar 20, 2019 8:30 am    Post subject: The collapse of footbridge at mumbai. Reply with quote
I think that there a need to overhaul the existing engineering practices to ensure that such disasters do not happen in future.SUCH OF THE SITUATIONS WHICH ARE NOT OPEN TO VISUAL INSPECTION WE SHOULD HAVE MUCH HIGHER FACTOR OF SAFETY IN DESIGN OF CONNECTIONS.
I want that the engineering  fraternity  sit together and apply their mind and cobble up a standard.structural audit when nothing is in view is an eyelash it was accordingly done the files complied as also some small slush money must have been shared by the people associated.
WE MUST MAKE STIPULATIONS FOR SUCH CONNECTIONS SITUATIONS.THESE WOULD PARTICULARLY HELPFUL TO USERS OF STEEL
Sktrisal
9910416668
On Wed, 20 Mar 2019, 13:03 Sushil Trisal, <sktrisal@gmail.com (sktrisal@gmail.com)> wrote:
[quote]The directions in respect of column 20 times the beam bar dia are not being followed.the dangers of non observance of this stipulation need to be highlighted.the approving offices should observe  these stipulations.Some positive steps need to be taken in this direction.
Sktrisal
9910416668
On Mon, 18 Mar 2019, 19:54 Rudra Nevatia, <forum@sefindia.org (forum@sefindia.org)> wrote:
[quote]            Thank you Sir for initiating discussion on IS:1893.
My comment relates to Clause 7.8.2 Design Eccentricity. Apparently, two methods are commonly used to account for this clause :
1. Shifting of modal mass in RSA
2. Adding effects of eccentricity obtained from a static analysis to RSA
Can some guidelines be provided as to the preferred method ?
Rudra Nevatia
On Mon, Mar 18, 2019 at 1:04 PM dcrai forum@sefindia.org (forum@sefindia.org))> wrote:
