srikrishnagrandhi SEFI Member
Posted: Fri Dec 21, 2018 7:13 pm Post subject: Brick wall plastering using sand zone |
Dear sefins,
Which type of sand zone used for plastering.as per is code
G.srukrishna |
sspawar ...
Posted: Fri Oct 22, 2021 11:49 am Post subject: |
Dear Sefian,
For plaster sand - sand should be generally 100% passed through 2.36 mm sieve.
SIEVE ANALYSIS FOR PLASTER SAND-as per Specification IS: 1542 – 1992 (RA 2014)
IS Sieve
Designation, Cumulative Percent, Requirement of Sand for Plastering as per Specification IS: 1542 – 1992 (RA 2014) Retained Passing|
10.00mm | 0 | 100 | 100 | 04.75mm | 0 | 100 | 95-100 | 02.36mm | 0.6 | 99.4 | 95-100 | 01.18mm | 14.6 | 85.4 | 90-100 | 600 Microns | 30.4 | 69.6 | 80-100 | 300 Microns | 50.6 | 49.4 | 20-65 | Regards
S S Pawar |
Posted: Fri Oct 22, 2021 2:32 pm Post subject: |
Exposed Plastering is generally done using 1 cement :3 Fine sand . But mixing some 1 part out of 3 parts coarse sand is beneficial for durability , though specs are for fine sand plaster.
For Plastering on walls needing Tiles finish , plaster shall be from all coarse sand in ratio 1:3.
Before plaster application walls must be watered on face followed by flashing of cement slurry. Also curing of plaster shall be done religiously.
Just a thought for durability. |
