Posted: Fri Sep 23, 2022 4:27 am Post subject: |
An Earlier post :
Few Codes on TIMBER / MASONRY
PostPosted: Thu Jul 15, 2010 12:14 pm Post subject: Few Codes on TIMBER / MASONRY
Few codes are listed as under:
TIMBER / MASONRY
TIMBER
IS 883 Code of practice for design of structural timber in building
SP-33 Handbook on Timber Engineering
SP-7 National Building code of India
Part-VI section -3 WOOD
IS 399 : Classification of Commercial Timbers and Their Zonal Distribution
IS 10754 : Method of determination of thermal conductivity of timber
IS1708 Method of testing small specimenns of timber
IS2408 Method of static tests of timber in structural sizes
IS287 Recommendation for Maximum permissible water content
of timber use for different purposes
IS2366 COP for Nail jointed Timber construction
IS 5390 COP for design of Timber ceiling
IS 1141 COP for seasoning of Timber
IS 11096 COP for design and construction of Bolt jointed Timber construction
IS 5390 COP for construction of Timber Floors
IS 401 COP for preservation of Timber
IS4983 COP for design and construction of Nail jointed Timber construction
IS4970 Key for identification of commercial timber
Structural Timber:
IS 3629 - Specifications for Structural Timber in Building
IS4891- Specifications for preferred cut sizes for Structural Timber
IS4924- Method of tests for Nail laminated Timber beams
Wood Products:
Plywood
IS 303 Specifications for Plywood for general puposes
IS 1328 Specifications for Veneered decorative Plywood
IS 1734 Methods of test for Plywood(20 Parts)
IS 4990 Specifications for Plywood for concrete shuttering works
IS 5509 Specifications for Fire retardent Plywood
IS 5539 Specifications for preservative treated Plywood
IS 7316 Specifications for decorative Plywood using plurality of vaneers
IS 10701 : Specification for structural plywood
IS 12077 : Code of practice for testing of timbers for plywood manufacture
IS 13957 : Specification for metal faced plywood
Particle Boards and Fibre Boards
IS 1658 Specifications for Fibre hard Boards
IS 1659 Specifications for Block Boards
IS 2380 Methods of test for wood particle boards(23 Parts)
IS 3087 Specifications for wood particle boards(medium density)
IS 3097 Specifications for veneered particle boards
IS 3129 Specifications for particle boards for insulation purpose
IS 3308 Specifications for wood wool building slabs
IS 3348 Specifications for Fibre insulationboards
IS 3478 Specifications for high density wood particle boards
Wood based Laminates
IS 3513 Specifications for high and medium density wood based laminates
IS 9307 Methods of test for wood based structural sandwich construction(8Parts)
IS 12823 : Wood Products - Prelaminated Particle Boards - Specification
Wooden door and window frames and shutters
IS 1003 Specifications for timber panelled and glazed shutters
Part 1 door shutters
Part-2 Window and ventilator shutter
IS 12896 : Classification of Indian timbers for door and window shutters and frames
IS 1826 Specifications for venetian Blinds for windows
IS 2191 Specifications for Flush door shutters(cellular & hollow core type)
IS 2202 Specifications for Flush door shutters(solid core type)
IS 4020 Methods of test for wooden flush dors
IS 4121 Specifications for Door ,window ,ventilator Frames
IS 4962 Specifications forwooden side sliding doors
IS 6198 Specifications for legged braced battened timber door shutters
IS 4913 Code of Practice for Selection, Installation and Maintenance of Timber Doors and Windows
IS 6198 : Specification for ledged, braced and battened timber door shutters
IS 10394 : Specification for wooden sleepers for railway track
IS 10753 : Code of practice for preservation of wooden sleepers for railway track by pressure treatment
IS 1329 : Specification for aircaraft timber (baulks and scantlings)
IS 1634 : Code of practice for design and construction of wood stairs for houses
IS 1898 : Specification for timber for aircraft construction in converted form (finished form)
IS 2178 : Specification for Timber for Use in Aircraft Propeller Construction
IS 190 : Specification for coniferous sawn timber (baulks and scantling)
IS 1900 : Method of tests for wood poles
IS 5978 : Code of Practice for Design of Wood Poles for Overhead Power and Telecommunication Lines
IS 6056 : Specification for Jointed Wood Poles for Overhead Power and Telecommunication Lines
IS 3386 : Specification for Wooden Fence Posts
IS 2203 : Specification for wooden cross arms
IS 2372 : Specification for timber for cooling towers
IS 4424 : Specification for timber for use in coal mines
IS 4907 : Methods of testing timber connectors
IS 4924 : Part 1 Method of test for nail jointed timber trusses: Part I Destructive test
IS 4924 : Part II : Method of Test for Nail-jointed Timber Trusses - Part II : Proof Test
IS 4913 : Code of Practice for Selection, Installation and Maintenance of Timber Doors and Windows
IS 2700 : Code of practice for roofing with wooden shingles
IS 3670 : Code of practice for construction of timber floors
MASONRY
(Section on Masonry to be referred)
IS 1905 : Code of Practice for Structural use of Un-reinforced Masonry
IS 2212 : Code of practice for brickwork
SP 10 : 5 Nomograms for Thickness of Masonry Walls
SP 20 (S and T) : Handbook on Masonry Design and Construction
IS 13077 : Guide for preparation and use of mud mortar in masonary
IS 13612 : Part 1 : Modular co-ordination for normal brickwork - Recommendation Part 1 Burnt clay bricks
IS 13613 : Recommendations for modular co-ordination in building industry: Location of structural walls and floor slabs
IS 14142 Code of practice for design and construction of floors and roofs with prefabricated brick panel
IS 14143 : Specification for prefabricated brick panel and partially precast concrete joist for flooring and roofing
IS 14213 : Code of practice for construction of walls using precast concrete stone masonry blocks
IS 1597 : Part 1 : Construction of Stone Masonry - Code of Practice - Part 1 : Rubble Stone Masonry
IS 1597 : Part 2 : Code of practice for construction of stone masonry: Part 2 Ashlar masonry
IS 2116 : Specification for sand for masonry mortars
IS 2117 : Guide for Manufacture of Hand-Made Common Burnt-Clay Building Bricks
IS 2180 : Specification for heavy duty burnt clay building bricks
IS 2185 : Part 2 : Specification for concrete masonry units: Part 2 Hollow and solid light weight concrete blocks (superseding IS:3590)
IS 2185 : Part 3 : Specification for concrete masonry units Part 3 Autoclaved cellular Aerated concrete blocks (Superseding IS:5482)
IS 2185 : Part I : Specification for Concrete Masonry Units - Part I : Hollow and Solid Concrete Blocks
IS 2222 : Specification for burnt clay perforated building bricks
IS 2250 : Code of Practice for Preparation and Use of Masonry Mortars
IS 2395 : Part 1 : Painting of Concrete, Masonry and Plaster Surfaces - Code of Practice - Part 1 : Operations and Workmanship
IS 2395 : Part 2 :Code of practice for painting concrete, masonry and plaster surfaces: Part 2 Schedule
IS 3466 : Specification for masonry cement
IS 4805 : Guide for Construction of Brick Kiln
IS 11650 : Guide for manufacture of common burnt clay building bricks by semi-mechanized process
IS 4860 : Specification for acid-resistant bricks
IS 4885 : Specification for sewer bricks
IS 5454 : Methods of sampling of clay building bricks
IS 9394 : Specification for stone lintels
IS 9893 : Specification for precast concrete blocks for lintels and sills
IS 12894 : Specification for fly ash lime bricks
-- ญญ
Posted: Fri Sep 23, 2022 4:46 am Post subject: |
IS codes on river training as well as River diversion works may help
IS 8408 - - Planning and design of groyens in alluvial rivers
IS 9461 - - guidelines for data required for design of temporary river diversion works
IS 9795- -guidelines for choice of type of diversion works
IS 10084 -criteria fordesign of diversion workscofferdams
IS 10751 - -planning and design of guidebanks for alluvial rivers guidelines
IS 10788(P1) - -cop for construction of diversion works--pt1cellular cofferdams
IS 12926 - -construction and maintenance of guide banks in alluvial rivers--guidelines
Posted: Fri Sep 23, 2022 6:17 am Post subject: |
Following IS Codes on Pwer Intake structures :
IS 9761 Hydropower intakes
IS 11388 Recommendation for design of trash racks for intakes
IS 11570 Criteria for hydraulic design of intake structures
Others :
Manual on Water supply (CPHEEO Manual) Govt of India
Book on Water supply by Santosh Kumar Garg - Intake wells
Posted: Fri Sep 23, 2022 7:29 am Post subject: |
Few IS Codes on Guniting , water stops , grout curtains in Dams
IS 13645 Guidelines for guniting of upstream face of masonry Dam
IS 12200 COP for provision of water stops at transverse contraction joints in masonry
and concrete dams
IS 8605 COP for construction of masonry in Dams
IS 11293(part II ) - - guidelines for design of grout curtains for masonry and conc gravity Dams. |
