rectangular hollow section purlins
Goto page 1, 2  Next
Er.shivani
PostPosted: Mon Aug 07, 2023 12:30 pm    Post subject: rectangular hollow section purlins Reply with quote
hii sir/mam,
I am designing a rectangular hollow section purlin.
what formula should we used to find plastic section modulus required to initially assume a section? can we use the formula given by gaylord as attached.
I cannot find any reference where clear design procedure of rectangular hollow section purlins is given as per IS800, it would be of great help if anyone could share the design procedure they follow to design SHS or RHS purlins.
Thanks in advance.
 Filesize:  334.42 KB
 Viewed:  163 Time(s)
R_Shenoy
PostPosted: Tue Aug 08, 2023 12:30 pm    Post subject: rectangular hollow section purlins Reply with quote
Please download tech literature for tata hollow sections. It contains section properties, allowable stresses, etc.
On Tue, 8 Aug, 2023, 15:53 Er.shivani, <forum@sefindia.org (forum@sefindia.org)> wrote:
           hii sir/mam,
Thanks in advance.
Download Attachments:
Binoy Bhuson Saha
PostPosted: Wed Aug 09, 2023 6:30 am    Post subject: rectangular hollow section purlins Reply with quote
In my opinion instead of retangular hollow section you may use pipe section.If the purlin is used for roof top composit section suitable channel section braced with bend rod may be used.
On Tuesday, 8 August, 2023 at 03:52:18 pm IST, Er.shivani <forum@sefindia.org> wrote:
hii sir/mam,
Thanks in advance.
http://www.sefindia.org/forum/files/img_20230807_174848_156.jpg
durai_sundaram
PostPosted: Wed Aug 09, 2023 7:30 am    Post subject: rectangular hollow section purlins Reply with quote
The same formula is given in Page 477 ( design of beams) in the book " Design of steel structures - Limit state method " by Dr. N.subramaniam.
M.Durai
On Wed, Aug 9, 2023 at 12:09 PM Binoy Bhuson Saha <forum@sefindia.org (forum@sefindia.org)> wrote:
On Tuesday, 8 August, 2023 at 03:52:18 pm IST, Er.shivani wrote:
hii sir/mam,
Thanks in advance.
Manas M Ghosh
Bronze Sponsor
Bronze Sponsor
PostPosted: Wed Aug 09, 2023 8:11 am    Post subject: Zp of RHS, SHS Reply with quote
The Values of Zp for RHS, SHS are available in Pages 796-796 of the book Design of Steel Structures by Dr N Subramaniun.
MMGhosh
mmg
PostPosted: Wed Aug 09, 2023 8:30 am    Post subject: rectangular hollow section purlins Reply with quote
MMGhosh
On Wed, Aug 9, 2023 at 12:42 PM Binoy Bhuson Saha <forum@sefindia.org (forum@sefindia.org)> wrote:
hii sir/mam,
Thanks in advance.
svgkrao
Dear all,
As per IS 800, RHS /SHS come under    closed section.   I designed RHS 150x100x3.6mm for 7.5m span purlins  as per IS 800 last year and executed the project. The owner and erection contractor appreciated RHS pulins after seeing some issues of Z purlins in surrounding sites.
On Wed, 9 Aug 2023, 12:49 Binoy Bhuson Saha, <forum@sefindia.org (forum@sefindia.org)> wrote:
hii sir/mam,
Thanks in advance.
Er.shivani
PostPosted: Wed Aug 09, 2023 8:52 am    Post subject: rectangular hollow section purlins Reply with quote
thanks all for your reply
sir, my question is,
as in case of channel or i section purlins we have a formula (as attached previously) to get plastic section modulus required and from there we assume a suitable section whose plastic modulus is greater than the required value.
In the same way do we have a formula to find required section modulus for square/ rectangular hollow sections.
Manas M Ghosh
Bronze Sponsor
Bronze Sponsor
PostPosted: Wed Aug 09, 2023 9:26 am    Post subject: Zp of RHS, SHS Reply with quote
Sir,
Can you share me the basis of the formula?
Zp of RHS and SHS are also listed in IS 4239.
MMGhosh
Er.shivani
PostPosted: Wed Aug 09, 2023 9:39 am    Post subject: rectangular hollow section purlins Reply with quote
the formula is given for channel and i section purlins in "Design of steel structures:Limit state method,N subramanian "
it is given on page no 480 equation 10.63
also it is used in example 10.11 of the book on page no 493-494
Goto page 1, 2  Next
Page 1 of 2
