how to create and analysis rcc and steel structre in staad
maheswaran
PostPosted: Sat Aug 13, 2011 4:25 am    Post subject: how to create and analysis rcc and steel structre in staad Reply with quote
sir i need full anylisis and design procedure in staad pro.. how to sesmic analyse in staad pro.. i need procedure to create model and analysis for steel and rcc structures.. please guide...
gvp.sagar
PostPosted: Tue Aug 16, 2011 6:25 am    Post subject: staad pro Reply with quote
first draw the plan of the structure fo rcc structure on staad by adding beams with perfect dimensions and copy the plan by using trnasitional repeat option .
and then select bottom plan nodes and project downwards to the depth of foundation and add fixed support to them
and then go to general tab and give cross sections for beams and columns
and then go to loads and in that loads go to load defnitions and in that select sesmic loads and click on add new
and give the zone details and building and click on generate
and then go to load case details and click on add new and select sesmic and give four types of loads like eqx,eq-x,eqz,eq-z
and then select eqx and give factor 1 and then select eq-x give factor-1 similarly for z
maheswaran
PostPosted: Wed Aug 17, 2011 7:31 am    Post subject: thank you for kind notes Reply with quote
sir, we dont want to cosider joint load on  the structural analysis for sesmic design... ??
