Suggestions
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 19th July 2004
cdeshpan
PostPosted: Wed Aug 11, 2004 1:04 pm    Post subject: Suggestions Reply with quote
I would like to thank the e-conference organizers, and
Prof. Durgesh Rai for sharing with us the draft code.
This code is of great interest and value. Some of my
initial suggestions are as follows:
1. Additional pictures/diagrams are necessary to
explain the various concepts in different parts of the
code: for example, a diagram will be useful to explain
the Section 7.4.1.1 (c) Mazzanines/loft/Sub-floor
bracing or anchorage concepts.
2. Section C5.4 "Using esablished field tests for
materials used" - A cross reference to existing codes
that describe the field tests or recommended field
tests may be necessary. It could be in a tabular form.
3. Strengthening section seems somewhat constricted to
me.  For example, the supplemental isolation (Section
8.3.1).  I feel that if this is recommended in case of
even a few structures, then some technical references
must be provided to direct the user to additional
sources of information on that subject.
-Chitra
Do you Yahoo!?
New and Improved Yahoo! Mail - 100MB free storage!
http://promotions.yahoo.com/new_mail
avkashikar
PostPosted: Sat Aug 14, 2004 6:58 am    Post subject: Suggestions Reply with quote
Instead of using 0.67 as constant reduction factor for reduced usable life
it appear to be more logical to use unity load factors for seismic load
combination. If both load factor of 0.67 and occupancy risk factor of 0.75
are used, the combined factor becomes 0.5. which means we are taking half
the seismic force compared to new building. Is it OK? Instead of this if
we adopt unity load factor for seismic load combination, it is like
designing  for ultimate strength without any additional safety factor.
One more reduction in seismic forces can be change in damping
corresponding  to stress level for which we are designing. Damping value
of 7% to 10% can be used for reassessment, which will reduce a seismic
force to major extent.
Arun Kashikar
TCE Consulting Engineers, Mumbai
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 19th July 2004 All times are GMT
