maheswaran SEFI Member
Posted: Thu Aug 25, 2011 8:50 am Post subject: y do we release the member in staad pro.. where should |
y do we release the member in staad pro.. where should v release the member start and end of the member..??
please guide me sir,,, |
biswajit.halder SEFI Member
Posted: Fri Mar 01, 2013 6:32 am Post subject: |
Generally we release members wherever there is absence of sufficient moment transfer and the connection is not fixed or rigid. |
a121s General Sponsor
Posted: Mon Mar 04, 2013 9:49 am Post subject: Member release |
I presume that you have a member between A and B, another member between C and D, and a 3rd member between B and D. By cantilevers, you are refering to the first and second members. Am I right?
If the 3rd member is merely resting on the first and second, and not attached through a proper moment connection in the case of steel, or a monolithic construction in the case of concrete, then you need to release MY and MZ on the first and second members. But MX should be released in one of those two only. Releasing MX on both of them will make the 3rd member torsionally unstable.
Alternatively, you can release MX, MY and MZ at node B of member 3, and MY and MZ at node D of member 3. In this case, you won't release anything in the first and third members. _________________ SHISHIR S. KADAM
M.Tech(Structures),A.M.I.E |
Vijay Solanki SEFI Member
Posted: Thu Sep 22, 2016 7:26 am Post subject: A video showing how to release moments in beams in staad pro |
Dear,
As you got the answer for why do we release moments in staad pro, here is a link showing how to release moments in beams in staad pro.
https://youtu.be/UcbelletS18 |
saikiran gone General Sponsor
Posted: Thu Sep 22, 2016 9:24 am Post subject: Re: y do we release the member in staad pro.. where should |
maheswaran wrote: | y do we release the member in staad pro.. where should v release the member start and end of the member..??
Hi Maheswaran,
Q. y do we release the member in staad pro
To make the pinned connection we release the moments in the member.
It depends on the engineer if he wants to make the beam simply supported (i.e want to transfer only vertical force not the moment, especially in secondary beams ) he can release the moments in staad.pro at both ends (start and end ).
If he wants to release the moment only at one end , he should define either Start or End release specification and assign to the beam at the required end.
With Best,
Saikiran. |
