Instability of Joint
karanderohan
PostPosted: Tue Aug 30, 2011 3:52 am    Post subject: Instability of Joint Reply with quote
I have modelled the simple module in STAAD-V8i (as attached below).After doing analysis there is warning of instability of joint (Joint No. 6).
I have gone through the previous discussions about this and I have done accordingly ( I have assigned moment release), but still I am getting the same warning.
Please assist me in this.
Thanks and Regards
ROhan
STAAD SPACE
START JOB INFORMATION
ENGINEER DATE 29-Aug-11
END JOB INFORMATION
INPUT WIDTH 79
UNIT METER KN
JOINT COORDINATES
1 0 0 1; 2 0 0 0; 3 1.5 0 0; 4 1.5 0 1; 5 0 1.5 1; 6 0 1.5 0; 7 1.5 1.5 0;
8 1.5 1.5 1; 10 0.75 4 0.5;
MEMBER INCIDENCES
1 1 2; 2 2 3; 3 3 4; 4 4 1; 5 1 5; 6 2 6; 7 3 7; 8 4 8; 9 5 6; 10 6 7; 11 7 8;
12 8 5; 13 6 10; 14 7 10; 15 8 10; 16 5 10; 17 2 5; 18 2 7; 19 3 8; 20 1 8;
DEFINE MATERIAL START
ISOTROPIC STEEL
E 2.05e+008
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-005
DAMP 0.03
ISOTROPIC CONCRETE
E 2.17185e+007
POISSON 0.17
DENSITY 23.5616
ALPHA 1e-005
DAMP 0.05
ISOTROPIC MODULE
E 2.5e+008
POISSON 0.3
DENSITY 164.136
ALPHA 1.2e-005
DAMP 0.3
END DEFINE MATERIAL
MEMBER PROPERTY AMERICAN
1 TO 4 9 TO 12 TABLE ST W4X13
17 TO 20 TABLE ST PIPS30
5 TO 8 TABLE ST PIPS40
13 TO 16 PRIS YD 0.05
CONSTANTS
MATERIAL MODULE ALL
SUPPORTS
10 PINNED
MEMBER RELEASE
16 START MX MY MZ
15 START MX MY MZ
14 START MX MY MZ
13 START MX MY MZ
LOAD 1 LOADTYPE None  TITLE DL
SELFWEIGHT Y -1 LIST 1 TO 20
PERFORM ANALYSIS PRINT STATICS LOAD
PARAMETER 1
CODE AISC
FYLD 248213 MEMB 1 TO 4 9 TO 12
FYLD 241290 MEMB 5 TO 8 17 TO 20
CHECK CODE MEMB 1 TO 12 17 TO 20
FINISH
gpsarathyy
PostPosted: Tue Aug 30, 2011 7:49 am    Post subject: Reply with quote
Dear Sefian,
You should not release all three rotations (Mx, My, Mz) for any beams at start or end. Restraint any one moment and check. Then it will be ok.
If you try the same in the GT strudl it will not even analyse. It will give the rotation warning.
CHENNAI
GPSARATHYY@GMAIL.COM
karanderohan
PostPosted: Tue Aug 30, 2011 9:12 am    Post subject: Instability of joint Reply with quote
Dear G.PARTHASARATHY
I have tried to release only single moment (either of Mx, Mx or My), but still same warning
gpsarathyy
PostPosted: Tue Aug 30, 2011 1:35 pm    Post subject: Reply with quote
Dear Sefian,
I also checked, it works without any member release only.
Then structural configuration has to be modified to avoid this warning.
Provide additional bracing and check.
CHENNAI
karanderohan
PostPosted: Wed Aug 31, 2011 11:12 am    Post subject: Instability of Joint Reply with quote
Dear Sefian,
As it is a sling (the tension member), so all the moments should be released, so as to ascertain that it is an axial member.
karanderohan
PostPosted: Wed Aug 31, 2011 11:22 am    Post subject: Instability of Joint Reply with quote
I have assigned the spring support with specified stiffness, in horizontal plane (X-Z), so as to restrain the horizontal motions that takes place during lifting.
Now I am not getting any instability warnings.
Please check with the attached file herewith.
Thanks and Regards,
Rohan
TAAD SPACE
END JOB INFORMATION
INPUT WIDTH 79
UNIT METER KN
JOINT COORDINATES
MEMBER INCIDENCES
ISOTROPIC STEEL
E 2.05e+008
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-005
DAMP 0.03
ISOTROPIC CONCRETE
E 2.17185e+007
POISSON 0.17
DENSITY 23.5616
ALPHA 1e-005
DAMP 0.05
ISOTROPIC MODULE
E 2.5e+008
POISSON 0.3
DENSITY 447.978
ALPHA 1.2e-005
DAMP 0.3
END DEFINE MATERIAL
9 TABLE ST W4X13
10 TABLE ST W4X13
12 TABLE ST W4X13
20 TABLE ST PIPS30
19 TABLE ST PIPS30
4 TABLE ST W4X13
5 TABLE ST PIPS40
6 TABLE ST PIPS40
17 TABLE ST PIPS30
18 TABLE ST PIPS30
11 TABLE ST W4X13
8 TABLE ST PIPS40
3 TABLE ST W4X13
1 TABLE ST W4X13
2 TABLE ST W4X13
7 TABLE ST PIPS40
CONSTANTS
MATERIAL MODULE MEMB 1 TO 12 17 TO 20
MATERIAL STEEL MEMB 13 TO 16
MEMBER RELEASE
13 START MX MY MZ
16 START MX MY MZ
14 START MX MY MZ
15 START MX MY MZ
SUPPORTS
6 FIXED BUT FY MX MY MZ KFX 5 KFZ 5
10 FIXED
PARAMETER 1
CODE AISC
FINISH
rahul.leslie
PostPosted: Wed Aug 31, 2011 11:26 am    Post subject: Reply with quote
I'm not sure whether this is what you wanted (attached). If it is the case, I shall explain what went wrong.
karanderohan
PostPosted: Wed Aug 31, 2011 12:15 pm    Post subject: Instability of Joint Reply with quote
Dear Rahul,
Please guide me in this case
Thanks and regards,
Rohan
