er_spsvasan SEFI Member
Posted: Mon Nov 17, 2003 9:01 am Post subject: Wind pressure coefficients - P.Aravan's message |
Hello Aravan,
The IS 875 seems to be using the term Pressure Cofficient Cp (= Cpe-Cpi) when dealing with normal buildings. The term Force Coefficient Cf seems to be used for structures like chimneys, watertanks, lattice towers etc, for which the the term internal pressure coefficient does not have any meaning.
We have to use either Cf or (Cpe-Cpi) depending upon the type structure.
While the force coefficient and the pressure coefficients give the value of pressure normal to a surface, the drag coefficient gives the value of pressure parallel to the surface (due to friction effect between wind and the surface). The use of drag coefficient depends upon the circumstance. For example, if we are designing a factory building, when we design the trusses, the drag force is not considered since the drag force is perpendicular to the truss and the truss is not expected to resist the same. However when we design the bracing system the drag force is to be considered while calculating the forces on the bracing system. Similarly when we design the frame supporting the trusses, the drag forces are to be considered. The drag forces are transmitted to the supporting frame through the bracing system. Ofcourse, if we are doing a 3 dimensional analysis, the drag forces are always to be considered.
Regards S.P.Srinivasan
___________________________________________________________
software.
________________________________________________________________________
